Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 15, 2021 at 6:21 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Anyone you recommend to do it? I was gonna ask my local dealer initially but wasn't sure if they would even do it.
    Cativelense likes this.
  2. Apr 15, 2021 at 6:37 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    The guy that did mine was great; recommended by another tw member on here; and has done a ton of the bushing installs. Hes in Florence Mass; is that within range for you?
    Skierrichy, TOMB and Cativelense like this.
  3. Apr 15, 2021 at 6:52 AM
    fourfourone
    Only about an hour from me. so that could work.
    Skierrichy and Cativelense like this.
  4. Apr 15, 2021 at 7:03 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Pm sent with his info
  5. Apr 15, 2021 at 9:12 AM
    TRD_Taco_No.2
    TRD_Taco_No.2 Member
    Rock
    CT
    2014 DCOR Super White
    This is real timely for me, I just bought my 2014 used with a lift and was trying to diagnose this vibration. Looks like I have it, strongest from 30-40, a kind of pulsing that goes away after about half my commute. I have a short warranty from the dealer, is it worth going after them to get it done? I should note that dealer says they replaced rack and pinion already, which now makes me think they addressed the symptom not the cause. If I go after the dealer for it, is there a way to inspect to verify the bearing is failing without disassembly so that we can show it needs to be done? The dealer is far enough away that they vibe will be gone by the time I get there.
  6. Apr 15, 2021 at 9:21 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    I thought most, if not all dealers would refuse to install an aftermarket part, such as the ecgs bushing. Someone correct me if I am wrong on this. But I thought it all boiled down to liability on installation of a non Toyota part.
  7. Apr 15, 2021 at 11:40 AM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    @mabepossibly I just found out that some snatch straps, like my ARB, have a lifespan. How long you ask? 10 snatches! Apparently Bubba/Yankum ropes don't have this but the ARB does. We used at least half of those at Sucker Pond! Granted it says "10 fully loaded snatches" and some of ours were more like tugs, but still
    I'm mad. Part of me says "use it until it breaks" but I also don't want anyone getting hurt when it breaks...
  8. Apr 15, 2021 at 11:51 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Wow, I had to google that myself. Like you said, most of the pulls we did the truck pulling couldn't get enough traction or room to make a full stretch.
    Cativelense and Skierrichy like this.
  9. Apr 15, 2021 at 11:55 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    I wouldn't trust the dealer to mess with anything that the dealer is unfamiliar with let alone work on your truck normally in general.
    Breakfast Taco and Cativelense like this.
  10. Apr 15, 2021 at 11:55 AM
    Checkers10160
    Chess
    I can't find anything from ARB yet, but it seems to be the general consensus... Looks like anyone getting stuck Saturday is on their own!
    Kidding, of course
  11. Apr 15, 2021 at 11:57 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    This is why you get people completely out of the way when you do stuff like that.
    Who knows anyway, it could have a defect and break the first try.
    I've seen a brand new which rope snap on first try, and it didn't get caught or hung up on anything and was a name brand.
  12. Apr 15, 2021 at 12:00 PM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    @MikefromCT
    Can you send me a link please for the leveling spacer thingy mujig?
    It would be helpful:thumbsup:
    Adam knows I'm coming I need to get stuff ordered.:annoyed:
    Let's see if I can keep it under 5000$:rofl:
  13. Apr 15, 2021 at 12:08 PM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Taco lean spacer? Do you know how much you need to correct?
    I went with a quarter inch spacer; because i need to correct the driver side a half inch.
    https://www.headstrongoffroad.com/store/p31/HS_1/4"_Top_Plate_Spacer_-_TT05514-TPS.html
    Also, news to me, headstrong got bought by tg..
  14. Apr 15, 2021 at 12:17 PM
    Checkers10160
    Chess
  15. Apr 15, 2021 at 12:23 PM
    fourfourone
    The way to tell if its the needle bearing is to put the truck in 4wd. If it immediately goes away, then its 99% the needle bearing. Some trucks have this vibration and no lift. It feels like a pulsing vibration on the floor board and pedals. Mine goes away as soon as I go over 45ish. Its deff like a buzzing vibration if that makes sense. It started happening literally on the test drive after installing my front Bilsteins.
    They may warranty the needle bearing but from what I have read that even a new oem needle will still go bad with a lift. Its a design flaw in the front diff. The needle bearing typically won't look bad when you inspect it either.
    Skierrichy, Schmidt6 and Cativelense like this.
  16. Apr 15, 2021 at 12:25 PM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Yea, i think they were family owned before. Not surprising shes no longer there under the new ownership. Disappointing because she was super helpful.
    I did reach out to tg when I got my ubolt flip and they were helpful. Not crapping on them; I just had a great experience through the Legacy Headstrong folks.
    Skierrichy, Cativelense and Bridge4 like this.
  17. Apr 15, 2021 at 12:26 PM
    TRD_Taco_No.2
    Rock
    CT
    Well that kind of sucks but it is what it is.
    How much am I looking at, ballpark?
  18. Apr 15, 2021 at 12:36 PM
    fourfourone
    I just bought the entire kit from ECGS to replace the bearing with their bushing. The kit is VERY over priced but I rather be prepared. It came with the bushing, install tool. puller tool, seal driver and OEM axle seal. Kit was 170 bucks. $60 for just the bushing. Seems like most places can do it rather quick. I've read 2 hours of labor should cover the job. I would say around $400ish all together. If you have someone do it who has an internal bearing puller kit then it will save you almost 100 bucks for the tool(super over priced from ecgs). I'm going to switch to lucas 85w140 per what ECGS recommends. The fluid drain and fill should only add a few mins onto the job.
    I am trying to get mine done next week. I am more then happy to let you borrow the tools after I am done as I am just gonna throw them up on the classifieds for half price.
  19. Apr 15, 2021 at 2:33 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I believe @tacobell007 does the bushing swaps at a reasonable price. I do have the puller and an install tool if you wanted to give it a crack.
  20. Apr 15, 2021 at 3:02 PM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Problem is, Drew doesn't live around here anymore. He's not in Western MA anymore. He's in NH now.
