Hey Hodge
Discussion in 'Suspension' started by jandrews, Jan 26, 2011.
  1. Jan 26, 2011 at 2:26 PM
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Got SnooperBumps?
  2. Jan 26, 2011 at 2:32 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I'm confused
  3. Jan 26, 2011 at 2:33 PM
    jandrews
    Acceptable.
  4. Jan 26, 2011 at 2:33 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    super bump
  5. Jan 26, 2011 at 2:33 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    You should be.....
  6. Jan 26, 2011 at 2:36 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  7. Jan 26, 2011 at 2:38 PM
    jandrews
  8. Jan 26, 2011 at 2:39 PM
    jandrews
    Nah, SupaBAMFs.
  9. Jan 26, 2011 at 2:54 PM
    jandrews
    Also got somma this coming: But with the drilled/threaded plates for timbren mounting. Gonna shoehorn these SuperHumps onto 'em.
    EDIT: Dan, I saw you watching! Get back to work, you lurkin' bastige!
  10. Jan 26, 2011 at 2:56 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    You wanna cookie?
  11. Jan 26, 2011 at 2:57 PM
    jandrews
    Chocolate chip please.
  12. Jan 26, 2011 at 3:01 PM
    jandrews
    Lurry are we on for this weekend or what mang?
  13. Jan 26, 2011 at 7:51 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    u dirty summmabitch!!!! i think i'm just gonna tack on the stockers if i can find them. tax returns should euqal ATO rear high clearance w/ tire carrier (maybe), snorkel, probably 4xi sliders, WOs for the front...and maybe a few other things.
  14. Jan 26, 2011 at 7:55 PM
    jandrews
    Yeah, pretty much my whole return is going to Mr. ATO for a full set of everything...sliders, skids, bumpers at both ends, along with some smaller stuff like shackle flips.
    These things are a new design though...they're definitely less squishy than the ones on your truck, and they seem a bit bigger too...
  15. Jan 26, 2011 at 7:59 PM
    jandrews
    Nah, already got a set of those.
  16. Jan 26, 2011 at 7:59 PM
    The_Hodge
    SC
    hmmm....definitely look different. cant say i like to color of the back ones.
  17. Jan 26, 2011 at 8:00 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Interested to see how well they mount up to the U-Bolt Flip Kit (waiting to be installed)
    Haven't purchased any bumps though,
  18. Jan 26, 2011 at 8:04 PM
    jandrews
    Easy fix with a rattle can.
    I'm wondering why the color difference...maybe a different density foam for the rear?
    Hope they still got that nice soft bottom. Also, these suckers are a good bit higher than the factory stops. I'm interested to see how articulation changes. Probably gonna lose a little travel.
    It'll take a little custom work...mainly drilling out the brackets with a uni-bit. Shouldn't be an issue. I might cut the upturned ends of the bracket off as well, although that's probably not necessary. U-bolt flip is on the way from All-Poo as of today. I have to admit, their customer service was good.
  19. Jan 26, 2011 at 8:07 PM
    theduck911
    Max
    Locked and Geared!
    Oh yea, for sure, that's what I was thinking since the new U-bolt design is meant for bolting on the timbrens so you'd just have to make holes in the superbumps at the same spot,
  20. Jan 26, 2011 at 8:07 PM
    The_Hodge
    SC
    it's a good possibility on the different foam.
    as for fitting them on the all pooh flips, i'd just drill out the holes like you said and cut off the ends just for good measure.
