Hey TW! Let's see your knives!
Discussion in 'Guns & Hunting' started by twistax, Jun 11, 2011.
  1. Feb 7, 2015 at 10:35 AM
    #2481
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    I take points off for proprietary screws. That's not a plus in my book. It's just another thing I need to buy. I don't even like the torx screws that Benchmade uses but at least they're common.
  2. Feb 7, 2015 at 10:42 AM
    #2482
    skygear
    skygear                    
    Most of the service is done for free at the factory. With all the OTF's you void the warranty opening them. Not that it has stopped me. For the average joe, you can soak them in a parts cleaner fully covered. Rinse out with distilled water then re lube with a quality oil. in-between all steps, dry with compressed air until you re lube.
    Only times i disassemble is when i am just bored and want to. There was one time in 09' when i had to replace a spring. 'The started using a different, better quality version since then. Could have sent it in, was quicker for them to ship to me due to my grave plans.
  3. Feb 7, 2015 at 11:03 AM
    #2483
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I'm OK with the Torx. The proprietary screws are dumb-there's really no need or advantage to that.
  4. Feb 7, 2015 at 1:22 PM
    #2484
    skygear
    skygear                    
    it was originally done to thwart clones. Then it just became a neat design aspect in my opinion. I like them .
  5. Feb 8, 2015 at 9:22 AM
    #2485
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Sshhh! I just ordered something.
  6. Feb 9, 2015 at 11:15 AM
    #2486
    skygear
    skygear                    
  7. Feb 9, 2015 at 2:04 PM
    #2487
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Started making my own Kydex sheaths last week. This was my first one. I wanted to turn my Helle into a neck knife instead of using that belt sheath it came with. I always carry scout style, but the Helle is so light I figured it would be light enough to go in a neck sheath.
    Used .128 Kydex in a press and it came out pretty good IMO for my first sheath. I need a new belt for my sander to finish removing some of the material outside of the eyelets, but it grips the knife nice and snug but is flexible enough that it pops in and out without wearing on the curly birch handle. Put a ferro rod holder on it as well. Let me know what you think.
  8. Feb 9, 2015 at 3:16 PM
    #2488
    aficianado
    back to bone stock.
    Awe damn. That is good! Very good. Does that Helle knock a pretty good spark off that ferro?
  9. Feb 9, 2015 at 3:58 PM
    #2489
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Nice! Looks great
  10. Feb 9, 2015 at 4:54 PM
    #2490
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Nice job.. you interested in any projects? :cool:
  11. Feb 10, 2015 at 4:47 PM
    #2491
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Well, it puts off a good spark but it's not carbon steel so it could always be better. I got the Fossekallen for less than $70 on an Amazon steal of a deal, but the carbon steel model they offer is $160+. I'll stick to carrying a cheap striker and not mess up the Helle blade.
    Thanks bud.
    Hmmm... hadn't thought that far ahead yet. Let me get good at more styles of knives and I may revisit this thought. What you looking at having done?
    Appreciate the compliment. I'll take another pic once I take the time to clean this one up a little tighter. I can probably grind another ounce or so of material off of it.
    My first attempt with .080 kydex on a large blade (my Ka-Bar combat kukri) had a different outcome. I've learned a lot since this sheath. Working with the thicker stuff means more time under the heat, and a quick set in the press. Plus I didn't tape the blade so it came out really snug and I had to do some tweaks with the heat gun. I also set the eyelets a bit far away from where the blade socket goes, so the next one will be much leaner and cleaner.
    I thought the carbon fiber texture was pretty cool, but I just wanted a tan sheath to match my pack and the carbon fiber was the only option at the time I was buying kydex.
    I used a Blade Tek molle attachment so I can throw this on my bug out bag very quickly. The Blade Tek also doubles as a belt loop so I can take it off the pack and clip it on my belt and carry at at a 45 degree angle. That part I was happy with.
    The next one will be leaner and meaner, and the blade will go in and out much better. This one is really snug but it still does the job and I'll keep using it until I replace it with a better-made sheath.
  12. Feb 12, 2015 at 12:40 PM
    #2492
    TheTemp
    TheTemp Halifax Edition
    Uriah
    Halifax, NS
    '15 Tacoma TRD DCSB 6M
    Toytec Boss Coilovers W/ Boss extended travel rear shocks and 2" AAL, LR UCAs, N-Fab Nerf Bars, Truxedo Lo-Pro QT Tonneau, 4" Shorty Antenna, Blacked out badges, Tinted Tails
    Had this fella come today....SOG TK02 Toothlock
    My 1st SOG, and I must say I'm very impressed. Another great addition to the trucks center console
  13. Feb 12, 2015 at 1:02 PM
    #2493
    T4RFTMFW
    I have a BK14 I want a scout style kydex sheath for with a TekLok. Your Blade Tek thing sounds interesting, though. I also have a Fallkniven F1 that could use the same treatment..
    I'll wait until you're interested! I don't have the fun money ATM for sheaths.
  14. Feb 12, 2015 at 1:33 PM
    #2494
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    So I put the Helle sheath back on the sander and took of the extra material and just gave it a clean-up. Also switched ferro rods for this new one which is much lighter/compact, and looks slick. Ran my lanyard cord through the top eyelet of it. This way I'll never lose the little striker it comes with. Slick little ferro rod should get about 1000 strikes. One end unscrews and has a handle with the rod, the other end unscrews to reveal the little carbon steel striker with handle. All is waterproof because there are little gaskets above the threads.
    The whole setup got lighter and more compact, making it a better neck knife setup now.
  15. Feb 12, 2015 at 1:40 PM
    #2495
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I have a plan for some stand-off Kydex attachments so a tek-lok can be installed closer to the centerline of the knife/sheath, similar to how you would do it for the BK2 using the stand-off that holds the stock nylon belt loop. I have a BK2 and am happy enough with the sheath after the tek-lok mod that I won't be making my own for it, but it gave me a good plan for doing other larger knives and having a tek-lok in a better location than being offset. That's probably what I'm going to build for the 2nd version of the kukri sheath.
  16. Feb 12, 2015 at 11:29 PM
    #2496
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Which would you choose?
    I've looked through quite a few knives and these are pretty much my two favorites for a decent price. The stainless Bowie comes with a nylon sheath and the damascus comes with a leather sheath.
    Or
  17. Feb 13, 2015 at 12:27 AM
    #2497
    skygear
    skygear                    
    What is the intended end use? just to have? the top one looks interesting.
  18. Feb 13, 2015 at 12:28 AM
    #2498
    skygear
    skygear                    
    on another note. I got one of the BG Pro black orange plain edges for 16 bnib
  19. Feb 13, 2015 at 9:19 AM
    #2499
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    This ^^
  20. Feb 13, 2015 at 10:19 AM
    #2500
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Thank you for your input, i think the one that looks like damascus said its made in pakistan(probably same quality as china..) I'm a noob when it comes to knives, could you guys point me in the right direction?
    Thanks
    no specific use.. just to have/fuck around with/self defense from animals (hiking/camping) and such haha. I just want a decent full tang knife.
