Hey TW! Let's see your knives!
Discussion in 'Guns & Hunting' started by twistax, Jun 11, 2011.
  1. Sep 15, 2014 at 6:42 PM
    #1621
    T4RFTMFW
    T4RFTMFW Well-Known Member
    The Bushcraft Black? Never seen a "tactical" Mora.
    They're great, scandis are super easy to sharpen to a hair popper.
  2. Sep 17, 2014 at 5:40 PM
    #1622
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Small little review on the CKRT knife the Drifter. It's been really good it's still super sharp and I've carried it every day since it arrived roughly 2 months ago I think.
    The only small issue I have noticed is that there is a nut that holds the blade centred and it seems to like to come loose. If you tighten it too much you can't open the blade up so there is a sweet spot you have to tighten it too and it's kind of a wonky bit that you have to use. When it comes loose it causes the top of the blade to scrape against the handle and it's worn off the coating on the blade. Really not a big deal and I would buy it again in a heart beat for $20.
  3. Sep 17, 2014 at 5:42 PM
    #1623
    T4RFTMFW
    That's the pivot pin. Throw some Loctite on it (not permanent bond) and set it where the blade is happy - easy to open, easy to close, no rubbing on the liners, and forget about it.
    Overtightening it will add a lot of friction to the blade where it rotates on the pin, between the liners. Hard to open, hard to close, coating wears off prematurely. Too loose, and the blade will have play in it both locked and unlocked, since it's not being held tightly between the liners and the washers that allow it to be held tight yet still rotate without much drag and friction.
  4. Sep 17, 2014 at 8:18 PM
    #1624
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Where can I find a good axe? I need one to carry in my truck for camping. Id prefer something without a wood handle but if it's a decent axe I can get over it. I really like the crkt ones but that's a lot to drop on an axe I know nothing about
  5. Sep 17, 2014 at 8:20 PM
    #1625
    T4RFTMFW
    Wood is superior. But if that's serious, a Fiskars. NOT a Gerber. And not the shit yellow handled plastic piece of crap from Home Depot.
    When you say don't know anything about, are you talking about the CRKT axe, or axes in general?
  6. Sep 17, 2014 at 8:47 PM
    #1626
    Boogyman
    Phoenix
    Corpus Christi, TX
    Both lol. I'm a huge crkt knife fan but idk if someone else makes there axes for them or if they make there own. There nice looking but it's more of a tomahawk than a true axe
    http://www.bladehq.com/item--CRKT-Johnson-Kangee-T-Hawk-Orange--21434
  7. Sep 17, 2014 at 8:58 PM
    #1627
    T4RFTMFW
    Would never suggest that as a tool. An Axe is meant to chop wood that entire CRKT tomahawk weighs less than an appropriate axe head weighs, without a handle.
    Also, an axe is serious. You can easily remove a foot with a single glancing blow. I would really recommend familiarizing yourself with proper and safe axe use before you buy one.
    If you're looking for a hatchet, and can't handle a wooden handle, I'd still recommend Fiskars. That CRKT is a "tactical" tomahawk and likely will be useless for legit hatchet usage. For $140 you can buy a hand forged axe from the finest Swedish manufacturer. A real axe that you can shave with.
  8. Sep 17, 2014 at 9:00 PM
    #1628
    T4RFTMFW
    A boys axe makes a good first axe for general use. But really, safety is paramount and axes are serious tools. Can't say that enough. There is no such thing as a minor injury when swinging an axe.
  9. Sep 17, 2014 at 9:09 PM
    #1629
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    What's wrong with a gerber hatchet?
  10. Sep 17, 2014 at 9:13 PM
    #1630
    Boogyman
    Phoenix
    Corpus Christi, TX
    Yeah I know there serious. Anything that sharp with that much weight behind it can be lethal. I need something for getting fire wood because the last trip I did everyone forgot firewood and all we had was one guys small hatchet and small machete and it made for a shitty firewood bundle and I really appreciate high quality knives and I assume axes are like knives in the way that you get what you pay for but idk where to start
  11. Sep 17, 2014 at 9:14 PM
    #1631
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    If I were going to be cutting serious wood I would think about a small chainsaw maybe.
    Cutting lots of wood is hard work
  12. Sep 17, 2014 at 9:17 PM
    #1632
    T4RFTMFW
    Gerber's QC is all over the place. Their hatchets/axes and Fiskars are nearly identical, but Fiskars have much less problems and so far as I've seen, better customer support to fix problems. Gerber's heads can be very poor quality, not sure if it's heat treating, grinding, or what, but they do something wrong
  13. Sep 17, 2014 at 9:19 PM
    #1633
    T4RFTMFW
    Look up Wranglerstar on YouTube. He has a few videos on axes around $50. Start there.
    Highly suggest a wood handle. Fiskars is a good axe if you want a different handle material. Amazon sells them.
  14. Sep 17, 2014 at 9:57 PM
    #1634
    T4RFTMFW
    Aka finest hand forged axe from the finest Swedish maker.
    But not what I'd suggest as a first Axe unless you're the type who wants the best you can get, even if you don't know how to use it yet.
  15. Sep 17, 2014 at 9:59 PM
    #1635
    T4RFTMFW
    He doesn't want a wood handle. :)
  16. Sep 17, 2014 at 10:00 PM
    #1636
    T4RFTMFW
    And he might remove half his leg with a GB.
  17. Sep 17, 2014 at 10:03 PM
    #1637
    T4RFTMFW
    Did yours come with varnish?
  18. Sep 17, 2014 at 10:09 PM
    #1638
    T4RFTMFW
    Durr. BLO is my choice. And Obenaufs for my leather.
  19. Sep 17, 2014 at 10:13 PM
    #1639
    T4RFTMFW
    Boiled
    Linseed
    Oil
    All you need for wood handles, any varnished wood handled implement gets sanded to bare wood and coated in BLO. No blisters, and the more use they get the smoother the shafts become. Just keep them oiled and maintained properly and they'll never shrink and loosen up, either.
  20. Sep 17, 2014 at 10:16 PM
    #1640
    T4RFTMFW
    Knifes and guns were my only passions for most of my life. I have gotten rid off nearly all my knives. Now I have a dozen users and one I can't bring myself to use. Rather beat up a Mora.
    BHK/Canteen Shop Woodcrafter.
    My absolute.favorite user is Fällkniven F1.
