HF Spring compressors and Northern Tool Strongway 3-Ton floor jack
Discussion in 'Product Reviews' started by Revelations, Oct 2, 2023.
  1. Oct 2, 2023 at 5:42 AM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    Both great products. The spring compressors:
    They come in a nice case. I had no issues using them. They state to not use an impact gun, but I did anyways. No issues with them. You just need to be careful not to get the socket too close to the spring or it will get stuck. The bolt that you turn is pretty close to the spring.
    The 3-Ton floor jack is as good as my old Arcan. Even better that it has a 20.5" height range. It's on sale at $150 for now and I got an extra 5% off by signing up for the email. Setup was easy and I had it lifting the rear end of the truck for about 6.5 hours while I replaced all of my shocks. I used it on the front to get my jackstands in place. It held steady with no indication that it was going to fail. Solid jack and a better price than comparable HF floor jacks.
    https://www.northerntool.com/produc...file-service-floor-jack-3-ton-capacity-113079
  2. Dec 31, 2023 at 7:34 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
