Hi from Canada
Discussion in 'New Members' started by lastchance10, Nov 10, 2017.
  1. Nov 10, 2017 at 7:49 AM
    lastchance10
    lastchance10 [OP] New Member
    06 blue Tacoma TRD
    I joined up to be able to talk to you's about ideas and problem solving on Tacoma's .I own a 2006 Tacoma TRD double cab Lg box, I have had owned 4 runner, a FJ in the past, other Toyota products ,I also have had many other makes of PU's , none have compared to Toyota vehicles.........but they are not perfect. The question I have is when I tried to select 4 wheel Hi the 4x4 indicator flashes and it doesn't shift into 4 wheel drive any ideas what to check first..snow on its way... thanks...In the mean time I will look and see if I can find out this info on other threads .
  2. Nov 10, 2017 at 10:44 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Have you tried moving forward a bit after putting into 4hi? Sometimes that can kick it in.
    BassAckwards likes this.
  3. Nov 10, 2017 at 12:35 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome aboard! Whenever i first bought my truck, i had a hard time getting the 4wd hi and lo to engage. Ive noticed its easier to get 4hi to engage while moving. From what ive read, the gears mesh better while moving vs sitting at a stop. Once you get 4hi to engage, id come to a complete stop put it in neutral and then try to get 4lo to engage. The first time is always the hardest after not engaging or using it for a long time. Ive started using mine at least 10 miles every month and its very easy to get it into 4lo now.
  4. Nov 11, 2017 at 7:27 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  5. Nov 18, 2017 at 8:44 AM
    lastchance10
    06 blue Tacoma TRD
    Had it checked out yesterday at the Dealer. Ended up being the Fr Diff actuator was pooched, not cheap, they volunteer to pay half because I just bought the vehicle back in May, I hadn't even used the four wheel drive yet'. Like they say use it or loose it,...will exercise the system once a month from now on !
