Hi, I am Genny, rear differential damaged
Discussion in 'New Members' started by Ogeniver1, Apr 25, 2022.
  1. Apr 25, 2022 at 3:59 PM
    Ogeniver1
    Ogeniver1 [OP] New Member
    Geniver
    06 4x4 AT 4.0L
    None
    06 4x4 has diff noise. In process of removing it. Can it be rebuilt?
  2. Apr 25, 2022 at 4:06 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Could we have more details?
    The diffies are pretty reliable. More often a bad wheel bearing will make you think the diffy is bad.
    Looking forward to more details.
    Welcome to the show. There is a huge knowledge base here and we all want to help.
  3. Apr 25, 2022 at 4:08 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    They can sort out location of noise with a stethoscope. What kind of modifications do you have? Wheel hard much? Tow stuff?
  4. Apr 25, 2022 at 4:47 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  5. Apr 25, 2022 at 4:48 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
    I’m sure you can find an answer here on TW :thumbsup:
  6. Apr 25, 2022 at 5:02 PM
    galaxyz
    galaxyz Well-Known Member
    2016 Tacoma TRD Off Road
    Welcome!
    Ogeniver1[OP] likes this.
  7. Apr 25, 2022 at 5:16 PM
    Ogeniver1
    Geniver
    06 4x4 AT 4.0L
    None
    Thank you guys!
    I read the posted threads previously as I was told by one analyst that I needed both right front and rear wheel bearings. I listened because I read about the reliability of of the differentials and the pinion bearing being always submerged in oil. I was about to purchase both when 2 friends advised that it’s unusual for those to go bad at the same time.
    Subsequently I took it to a mechanic, he jacked up the rear wheels and removed the drawing shaft, then turn the wheels. One could hear the loud rough sound emanating from the diff itself. Hence my wait until he remove the food entirely. In the AM I will get the diagnosis. hence my question, what can I expect? Anxiety is having the best of me,
  8. Apr 25, 2022 at 5:22 PM
    koditten
    Kirk
    Central Michigan
    The easiest diagnoses will be draining the fluid from the diffy, then straining that fluid. Any carnage will show up in the diffy fluid. A lot cheaper, too.
  9. Apr 25, 2022 at 6:30 PM
    Ogeniver1
    Geniver
    06 4x4 AT 4.0L
    None
    But how do I know to what extent is the damage?
  10. Apr 25, 2022 at 6:50 PM
    koditten
    Kirk
    Central Michigan
    If you see chunks of metal, you have problems.
    Metal smaller than glitter, not as big a deal.
    A half assed mechanic should be able to discern if the diffy is bad just from looking at the oil.
  11. Apr 25, 2022 at 7:31 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    If it’s toast the diff oil will be full of silver glitter and likely chunks of metal on the drain magnet.
    A blown diff roars pretty loud. Worst case you need a rebuild which isn’t a super expensive repair.
    Ogeniver1[OP] and wilcam47 like this.
  12. Apr 26, 2022 at 6:00 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  13. Apr 26, 2022 at 12:00 PM
    Ogeniver1
    Geniver
    06 4x4 AT 4.0L
    None
    Diff has cuttings in the oil; both pinion bearing worn. Will need to do a rebuild: I s it necessary to change all 4 bearings: Front & rear plus 2 side ones?
  14. Apr 26, 2022 at 7:19 PM
    koditten
    Kirk
    Central Michigan
    I'd like to see a pic of what they are calling "cuttings".
  15. Apr 26, 2022 at 7:45 PM
    Ogeniver1
    Geniver
    06 4x4 AT 4.0L
    None
    Viewed the larger of the two pinion bearings, the rollers are very worn, actually loose fitting in the slots but have not actually fallen out! And I didn’t actually inspect the oil !
  16. Apr 26, 2022 at 7:50 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    If the axle is apart, may as well redo all bearings
  17. Apr 26, 2022 at 7:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  18. Apr 26, 2022 at 9:09 PM
    Ogeniver1
    Geniver
    06 4x4 AT 4.0L
    None
    Thanks guys for all the advice!
    I got an education!
    TnShooter likes this.
