Hi I'm a new Member.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jhh2005, Jul 26, 2022.
  1. Jul 26, 2022 at 7:54 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    My 05 2.7L manual belonged to my brother in-law.
    It has 244k miles
    It sat for about 4 weeks. I tried to crank it a couple of days ago. It turned over normally 2 or 3 times. Then it sounded different and turned slower. It didn't crank. I replaced the starter. No difference. I checked compression the cylinders have about 30 lbs each.
    I appreciate any ideas
    I'm glad I found you guys
    Thanks in advance
  2. Jul 26, 2022 at 8:15 PM
    Waasheem
    Waasheem
    2007 xrunner
    Something’s wrong, 30 is super low. Check if there’s oil in it. Or a big leak and puddle under it.
    Jhh2005[OP] and Geeves77 like this.
  3. Jul 26, 2022 at 8:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You need the engine to spin “fast” to get a decent compression reading.
    Was it spinning fast or slow? How is the battery?
  4. Jul 26, 2022 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try jumper cables or a new battery
  5. Jul 26, 2022 at 8:50 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    It spun slow even with the plugs out. I'll put the charger on lt tomorrow. Oil is good it has a hundred or so miles on the change no leaks. Thank you
    JGO likes this.
  6. Jul 26, 2022 at 9:03 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This^^^. With what you describe I first check the battery. I hope you checked the battery before you replaced the starter.
  7. Jul 26, 2022 at 9:47 PM
    Huckin Grate
    Huckin Grate Well-Known Member
    Calgary, Alberta
    2008 SR5 MT V6 4x4
    X2 this
    AJKlug1 and Jhh2005[OP] like this.
  8. Jul 27, 2022 at 5:41 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Check the voltage on the battery....Do you know when the battery was changed last?
    Jhh2005[OP] likes this.
  9. Jul 27, 2022 at 6:20 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    I would have the battery load tested and just not "charge it" as it may TAKE a charge to 12.6 or whatever volts...but not have the oomph (amps) to crank the engine..take the battery to any auto parts store and they can test it for you. Im guessing the low compression is from the slow turn and possible blow by, just my thoughts.
  10. Jul 27, 2022 at 6:54 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    Thank you everyone for sending me in the right direction. I charged the battery and turned the charger on jump. It did the same thing. I thought maybe the battery cable is bad. With the charger on jump I clamped it to the bolt on top of the cable end. It spun over normally. Now I have to clean it all up. Again Thank everyone
  11. Jul 27, 2022 at 6:59 PM
    Waasheem
    Waasheem
    2007 xrunner
    Btw, welcome to the forum.
  12. Jul 27, 2022 at 8:09 PM
    MSgt O
    2013 Tacoma
    this is a REALLY great place...everyone here is just super helpful and nice...Not nearly as toxic as most forums!
  13. Jul 27, 2022 at 8:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's because Tacomas aren't like most other vehicles :)
  14. Jul 27, 2022 at 8:22 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Welcome to the forum.
    Thanks for the update :thumbsup: . Too many people post a question, issue that they are having. But never get back to us as to what the solution was.
  15. Jul 30, 2022 at 6:43 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    Update Thank you for the replies. I had the battery test. It was good. I cleaned the battery terminals. The engine turned over at normal speed. It did not start and acted as if it wouldn't catch up. My guess, the timing was a little off. I got my phone to video this. I turned it over and started. There was a loud rattle. This is the first time I have heard this. Is there anything I should be looking out for. Thanks in advance
  16. Jul 30, 2022 at 7:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    How was the battery tested and cleaned? The rattling noise could possibly be the alternator straining to charge the battery.
  17. Jul 30, 2022 at 7:53 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    I am installing a radiator. So drive belt was off.
  18. Jul 31, 2022 at 9:38 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Start with the cheap stuff first. A digital multimeter is a cheap and essential tool that can help diagnose many electrical issues.
    Lots of great people here but don't let anyone tell you that you have a bad head gasket because it's an 05.
    Hyperbarics and Jhh2005[OP] like this.
  19. Jul 31, 2022 at 12:14 PM
    Waasheem
    Waasheem
    2007 xrunner
    For multimeters, if you can, get one that has peak high hold and peak low hold. You probably don’t need to get a $500 fluke, but the cheap $20 ones are cheap. I’ve had es, amprobe, and a cheap $12 one years ago. Now just flukes. If I were to get just one, I’d go with one that has a ac/dc amp clamp.
  20. Aug 4, 2022 at 9:40 PM
    Jhh2005
    Jhh2005 [OP] Member
    2005 plain jane
    Update I figured out the camshaft phaser had a one time issue. So far. Possibly from sitting idle for a month. I put a new radiator, idler pulley, and a set of ruthinium plugs. It is running good now. I appreciate the shared knowledge
    Rick's 2012 likes this.
