Hi I'm new here and I don't read or spell the best so please hang with me thanks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hater71, Jan 25, 2016.
  1. Jan 25, 2016 at 4:37 PM
    Hater71
    Hater71 [OP] New Member
    2002 Tacoma
    Leveling kit springs off a one ton and flat bed with a extra gas tank
    I have a Tacoma 4 door and its bin running like crap up and down on the idle no power brought it to a friend and he said its Miss firing on all 6 cylinders get it to the speed like 60 it seems to run good tell you need more gas then it will shudder pop threw intake it will start and idle just no power smells like gas died couple times at stop sign or just sitting and idling any help be good thanks
  2. Jan 25, 2016 at 4:39 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Not sure if troll or...
    Joe D likes this.
  3. Jan 25, 2016 at 6:19 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    first, welcome to TW.
    second, you should edit your post and use punctuation at key points to separate your thoughts.
    third, you'll need to provide a little more information, like CEL (Check Engine Light) codes, anything new you've done or changed on the truck, was it progressively worse over time to all of a sudden, etc
  4. Jan 25, 2016 at 8:28 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    It wouldn't even run if it was misfiring on all cylinders. I'd recommend getting the codes read, starting with a tuneup and going from there.
  5. Jan 26, 2016 at 12:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If it runs that poor I would venture at least one code is present or more.
    If you plan to work on your OBDII vehicle a simple code reader is a must .
  6. Jan 26, 2016 at 8:44 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    bad MAF sensor maybe? it barely runs when those go bad
    Fenwick1993 likes this.
  7. Jan 26, 2016 at 9:23 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Mine only had a slight stumble on takeoff when mine went bad along with bad mpg. But op get the codes since I assume there are some then go from there
  8. Jan 26, 2016 at 9:29 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    I will hang with you
  9. Jan 26, 2016 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Symptoms of a clogged fuel filter.
