Hi-lift 48" vs 60"
Discussion in 'Off-Roading & Trails' started by FARNORCAL, Nov 30, 2014.
Hi-lift length and metal poll
Poll closed Nov 30, 2015.
  1. Hi-lift 48" Cast
    0 vote(s)
    0.0%
  2. Hi-lift 60" Cast
    6 vote(s)
    54.5%
  3. Hi-lift 48" Cast / Steel
    5 vote(s)
    45.5%
  4. Hi-lift 60" Cast /Steel
    0 vote(s)
    0.0%
  1. Nov 30, 2014 at 8:36 AM
    FARNORCAL
    FARNORCAL [OP] Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    It the market for a hi-lift and am not sure if I should go 48" or 60" which would you go with?
    Also I'm looking at the Cast and Cast/ Steel unsure between the two as well
  2. Nov 30, 2014 at 12:09 PM
    BradyT88
    BradyT88 Well-Known Member
    I got the 60" cast. Once you throw 33's+ and an aftermarket leaf pack on the rear the 48" jack will start to run out of lift just to get the rear tires off the ground.
    I went with cast because it's supposed to be a little more rugged and was only a few dollars more on Amazon.
  3. Nov 30, 2014 at 1:37 PM
    FARNORCAL
    SEE BUILD
    Yeah that's what I was thinking
  4. Dec 1, 2014 at 12:01 PM
    FARNORCAL
    SEE BUILD
    Bought the 60" Cast
  5. Dec 13, 2014 at 6:30 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    u know u can use a ratchet strap and limit the axle travel so it doesn't droop when u jack it up....just sayin
    TheGreatWhiteBuffalo likes this.
  6. Dec 13, 2014 at 7:22 PM
    FritzTKatt
    FritzTKatt Well-Known Member
    San Diego area
    6" Fabtech, sub-humanoid operator
    Good call, basik. Have put coil springs back in place on the trail using them... Wouldn't have though to use as limit straps in that situation though.
    You'd need some beefy straps or double/triple them up, though. I have yet to take a ratchet to the face and want to keep it that way!
  7. Dec 13, 2014 at 10:19 PM
    Basikbiker
    Trav
    Yea u need like one of those big trucker yellow ones, it's literally the only way to change a tire on a crawler out on the trail
  8. Dec 14, 2014 at 8:47 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    That's a really good idea. I wish I'd known about this before. Thanks, this is probably one of the best things I've learned in the past few months.
  9. Dec 14, 2014 at 8:59 AM
    jsi
    jsi Well-Known Member
    native earthling
    My Hi-Lift jack is a 48" cast model that is pushing 50 years old. I've never needed more than that, even with my lifted jeep. That said if I were going to replace it I'd go with the 60" cast model. Keep it dry and lubricated and you will be giving that jack to your great grand kids.
