Hi-lift jack accessories
Discussion in 'Off-Roading & Trails' started by bushman31, Aug 27, 2016.
  1. Aug 27, 2016 at 8:09 PM
    bushman31
    bushman31 [OP] Well-Known Member
    Ron
    Draper, UT
    TRD
    Old Man EMU suspension, 33" tires, 4.56 gears, Leer shell, airlift airbags, Fab 4's rear bumper and tire carrier, and some other shit.
    I was wondering what Hi-Lift jack accessories everyone has found to be the most useful. My DCSB Taco has N-Fab wheel to wheel nerf steps, stock bumpers, and Outlaw II wheels.
    Thanks,
    Ron W.
    Shmellmopwho likes this.
  2. Aug 30, 2016 at 3:05 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You'll want the wheel mate attachment in order to use the jack as a jack. Without frame mounted sliders or solid bumpers it won't do you any good otherwise. You can also use it as a come along to winch a truck. It takes some patience and a lot of resetting the equipment and chocks but it will work.
  3. Aug 30, 2016 at 12:50 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    A wider base plate to set the jack on - specially in softer surfaces. You can purchase a special plastic base, or bring along a small square of 3/4" plywood (12"x12" or so)
  4. Aug 30, 2016 at 8:52 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    The lift mate so you can hook it onto a wheel and lift it off the ground.
    Mounting brackets to secure the jack and keep it from flying around.
    The rubber bit that holds the handle and keeps it from rattling.
    A wider base.
    A shovel.
  5. Aug 30, 2016 at 8:59 PM
    GYOAZ
    GYOAZ Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    If you have a tow package the hi lift fits nicely into the 2" receiver. Just be very cautious as your truck will likely have the whole rear end lifted if you use that method for recovery. The best accessories would be swapping your nerfs for a set of sliders and the hi lift ORK.
  6. Aug 30, 2016 at 9:02 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
  7. Aug 31, 2016 at 5:50 PM
    bushman31
    Ron
    Draper, UT
    TRD
    Thanks guys for the info. One thing I was wondering was if I could use the slider adapter on the N-Fab nerf bar. Definate no on that. I assume the sliders would have to be welded on?
  8. Aug 31, 2016 at 6:05 PM
    GYOAZ
    Gary
    Tucson, AZ
    They make some really good bolt on sliders. I've got a set of demello bolt ons and they are super tough. Also check out SOS off-road, they're pretty competitive price wise and do great work. The Nfab nerfs will fold under the weight of your truck and probably dig into the body. If you're looking to upgrade you should have no trouble selling the nerf bars on the tw marketplace.
    bushman31[OP] and Shmellmopwho like this.
  9. Aug 31, 2016 at 6:26 PM
    bushman31
    Ron
    Draper, UT
    TRD
    Thanks Gary.
