Hi lift jack and stock tacoma 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by urchim, Sep 22, 2016.
  1. Sep 22, 2016 at 12:58 PM
    urchim
    urchim [OP] Well-Known Member
    Tacoma 2016 TRD Offroad Inferno
    question i am planning my next trip to moab and seen few people on trails with hi lift jacks, but most of the rigs were decked out with custom bumpers etc, my question is does hi lift jack do anything for stock bumper set tacoma? dont think u can lift sides of the rig with it ether, anyone have any pointers how to use it on 2016 trd offroad or stick with factory provided one?
  2. Sep 22, 2016 at 1:01 PM
    Large
    Large Red
    only way i can see you using a high lift on a stock taco would be in the hitch receiver and I still wouldn't do it
  3. Sep 22, 2016 at 1:01 PM
    Large
    Large Red
    They do make straps though for your tires if you want to go that route
  4. Sep 22, 2016 at 1:03 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  5. Sep 22, 2016 at 1:15 PM
    urchim
    i am assuming this would be used to get tire out of sticky situation or off rock so that u can put stuff under, but tire replacement in the field more likely use the stock lift
  6. Sep 22, 2016 at 1:17 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    it can be used as a slow ass winch if needed
    Joe23 likes this.
  7. Sep 22, 2016 at 1:23 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Yeah. You would use it to lift that tore up to be able to put something underneath it.
    But to change the tire. No. You'd need sliders for those. And having the stock jack for swapping a spare can be interesting. Make sure you bring some blocks of wood to help hit the truck in a low spot.
  8. Sep 22, 2016 at 1:33 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    if you're going to use a hi lift to change a tire I'm sure many would agree with me when changing put something, anything, another tire, an axle stand (if you have one) anything possible under the vehicle so if it falls you dont get crushed or the truck falls with no wheel and gets damaged in the one hub with no tire on it.
    Hi lifts can be extremely unstable once off the ground. Really recommend you use the hilift add on base as well.
  9. Sep 22, 2016 at 1:41 PM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    x2 I've had to do this a couple times. Not ideal but it works.
    JimboAnz[QUOTED] likes this.
  10. Sep 22, 2016 at 2:04 PM
    urchim
    so if i understood correclty, if u do end up in bad situation lets say tire jumped off rim, or got cut, hijack is useless unless u have sliders that can handle weight of truck and obvous reasons use hijack base, but other than that most people use it to lift via tire off stuck rock, or use it as poorman winch setup, is that the jist of it?
  11. Sep 22, 2016 at 2:18 PM
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
