Hi-Lift Jack in Pelican case
Discussion in 'Off-Roading & Trails' started by Bpl70, May 17, 2020.
  1. May 17, 2020 at 9:15 AM
    Bpl70
    Bpl70 [OP] New Member
    Brian
    2019 Tacoma TRD OffRoad
    Hello
    Is anyone running a Hi-Lift jack mounted inside a Pelican case that mounted to the roof rack?
  2. May 24, 2020 at 10:05 AM
    Biohazard495
    Biohazard495 Active Member
    Andrew
    2016 Black Tacoma TRD Sport
    Prinsu Roof rack RCI rock sliders KB Voodoo bed rack
  3. May 24, 2020 at 10:13 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Why in God's name would you put a Hi-Lift inside a pelican case? You afraid the paint will get ruined? lol
    Use the pelican case for other recovery gear.
  4. May 24, 2020 at 12:53 PM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Also why would you want to put all that weight up high on the roof.
  5. May 24, 2020 at 1:00 PM
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    I have an old highlift somewhere and a pelican 1700.. I could see if it will even be possible without taking the jack all apart
  6. May 26, 2020 at 10:51 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Because roof racks. "All that weight" is about 28-35 pounds. A 5 gallon gas can, full, runs about the same. What would you rather have on your roof rack? Certainly you've seen both, and more, on a roof rack?
    There are valid reasons to have a hi-lift on the roof, there are valid reasons not to. It comes down to a choice based on several factors, enough so it depends on the situation, it's not a yes or no answer.
    Matic likes this.
  7. May 26, 2020 at 10:55 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I just throw mine in the bed of the truck.
    Works for me.
    Hobbs and JMcFly like this.
  8. May 26, 2020 at 10:57 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I agree putting it inside of the case is a waste of money. A pelican case to fit it is going to cost more than the lift is worth.
    If you want it on the roof rack, just attach it directly to the rack.
    Edit: 1750 is $270. A 48" hi-lift is $85.
    Mully and Kyitty like this.
  9. Jun 11, 2020 at 5:57 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I was thinking of putting my spare tire in a pelican case, too, but it's hard to find one big enough... :rofl:
    Seriously, there's no need to do that. That's extra money, extra space, and extra weight. You can't damage these things, if that's what you're afraid of.
    Bring a can of spray lube, and give it a little razzle dazzle before each use.
    Mully, Hobbs and JMcFly like this.
  10. Jun 11, 2020 at 11:23 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Even if the elements get to the pins and springs Hi Lifts are easily rebuilt. Mine dates back to the 80’s and still works fine.
    Mully likes this.
  11. Nov 26, 2020 at 5:39 PM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
  12. Nov 26, 2020 at 5:43 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Hi-Lift - 15 overlander points
    Pelican case - 3x points multiplier for each item in case
    Roof Rack - 15% point increase for each item mounted to rack. Racks do not stack.
    You Suck I Suck More likes this.
  13. Nov 26, 2020 at 5:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I saw a guy on Instagram last week that kept his whole truck in a Pelican case. Was so fucking sick.
  14. Jan 7, 2023 at 9:05 PM
    splash07s
    splash07s Well-Known Member
    Lauton
    Charleston, South Carolina
    2014 TRD Sport 4X4 DCSB White
    are people on here always this toxic, damn folks. I can think of several reasons why a rack mounted pelican case might be a good place. For me it makes sense to save head clearance so I can actually park in my two car garage since the alternative is mounting it on the rack with the large runner sticking up above the rack several inches.
  15. Jan 7, 2023 at 9:34 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I will say this, hi lifts don’t do well in constant exposure. I left mine connect to my spare tire carrier on my Jeep TJ when it became a designed trail beater, and the jack rusted to hell in all the wrong parts.
    Later in the military one of my dudes had one of the pins failed to slide correctly from the dirt getting in the grease, and got some teeth out nocked out. It was found out later because the issue was able to be replicated. The pin wouldn’t slip in all the way on the climb.
    I don’t even really fuck with them anymore. I find a bottle jack more useful on the trail, but if I did have a farm jack, id probably put it in a case.
