Hi-Lift Jack mounting
Discussion in '1st Gen. Tacomas (1995-2004)' started by MurkEm, Jun 4, 2017.
  1. Jun 4, 2017 at 4:38 PM
    MurkEm
    MurkEm [OP] Well-Known Member
    Rocky
    2002 Lunar Mist Taco DBL Cab 4x4
    Toytec Boss Lift, Total Chaos UCA, OME Dakar Leaf, FN Wheels 5-Star, Federal Couragia MT's
    Trying to figure out some ways to mount recovery gear in the taco.Recently got into a group buy on a Hi-Lift Jack. Wanted to know how you other 1st gen guys mounted your jack and shovel? Quick fists maybe? I wish our trucks came with the newer gens bed rail system because theres alot of companies that have different mounting brackets specifically made for stuff like this..
  2. Jun 4, 2017 at 8:05 PM
    roosterburm
    roosterburm Well-Known Member
    Ross
    2002 Tacoma Double Cab 4 x 4 TRD
    3" Toytec with bilsteins American racing 15' wheels 32'' Goodyear MTR's Daystar super shackles
    MurkEm[OP] likes this.
  3. Jun 4, 2017 at 9:42 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    60" mounted to the pass. fire wall, weight supported atop the fender.
    Utilize these mount(s)...
  4. Jun 4, 2017 at 11:51 PM
    roosterburm
    Ross
    I have the same mounts. How does it not go all the way through the side of the bed ?
  5. Jun 5, 2017 at 4:45 AM
    MurkEm
    Rocky
    X2 can't seem to find where I can drill through and still be able to secure it with a washer and nut.
  6. Jun 5, 2017 at 4:54 AM
    Phessor
    Phessor Well-Known Member
    I made these using 1-1/2" strap and some bolts.
  7. Jun 5, 2017 at 9:00 AM
    MurkEm
    Rocky
    What bed rail system is that ?
  8. Jun 5, 2017 at 9:03 AM
    Phessor
    It came off a 2nd Gen Tacoma. Drill holes and bolt it in.
    MurkEm[QUOTED][OP] likes this.
  9. Jun 5, 2017 at 1:41 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    The bolts only go thru the interior surface of the bed.
    It's a 2 person task
    It is a tight fit to get your hand or a wrench between the inner and outer wall(s).
    but it can be done as I have.
    In my case I had to hold the nut over the hole drilled...
    then turn the bolt, in order to get the thread started in the nut.
    I also used large fender washers under the nuts to be sure they can't be pulled thru the sheet metal, due to stress or fatigue.
    I then used a closed end wrench to hold and a 2nd person on the inside, tightening that bolt using a socket and ratchet.
    Small hands are helpful when reaching up in between the inner and outer skin.
    Warning
    When drilling those holes into the inner wall/skin...
    be sure the drill bit is limited from drilling too deep because it could hit the outer fender skin, if not careful.
    There are drill stops (depth limiters) that can be used for this... tho' I simply used a piece of tape on the drill bit to determine its depth.
    But the later requires careful drilling... cause if the drill bit punches thru abruptly...
    It can put an outward dent in the outer fender skin.
  10. Jun 5, 2017 at 1:50 PM
    roosterburm
    Ross
    Did you remove the tail light ??
  11. Jun 5, 2017 at 2:46 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Inside my tool box until I destroyed my tool box on a tree, and it's now mounted to my internal cage with some muffler clamps.
    Try to store it in an enclosed space, using a rusty hi lift sucks.
    ThunderOne and MurkEm[OP] like this.
  12. Jun 5, 2017 at 3:31 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    been years... but think I needed to for the rear mount/nut access.
  13. Jun 5, 2017 at 7:24 PM
    MurkEm
    Rocky
    ive always wondered if i can do this. this can be a option for me mounting it cause i know other offroad companys have made brackets for the hi lift jack
  14. Jun 5, 2017 at 7:30 PM
    Phessor
  15. Jun 6, 2017 at 2:30 PM
    MurkEm
    Rocky
  16. Jun 6, 2017 at 3:02 PM
    Phessor
    I can take some pictures tonight. And no, no trimming.
    All I had to do was drill the holes in the bed and bolt them in.
  17. Jun 6, 2017 at 3:06 PM
    MurkEm
    Rocky
    self tapping screws? or bolt, nut, and washers ?
    i appreciate it. just trying to see how it all lines up and the fitment. cause I also have a camper shell and full bed liner. so im guessing id have to remove my bed liner to incorporate the rails
  18. Jun 6, 2017 at 8:46 PM
    Phessor
    I used the factory torx head screws from 2nd gen Tacoma and picked up some metric nuts and washers. Make sure you have your shell on when you install them. I didn't the first time and had to move them a little.
  19. Jun 6, 2017 at 8:56 PM
    MurkEm
    Rocky
    you're the man ! i appreciate it again!
  20. Jun 6, 2017 at 8:57 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I made custom brackets. Never moves. Details in my build
