Hi Lift Jack Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Apr 30, 2019.
  1. Apr 30, 2019 at 1:59 PM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    So I have a 2016 with 2.5 inch ADS reservoir shocks front and rear and medium Dakars in the rear. I also have RCI rock sliders.
    I have been experimenting with a Hi Lift 48 inch jack. My basic problem is jacking a rear tire (front is easy). I use the rear of the slider as a Hi Lift attachment point and here is the thing: there is so much travel in the rear suspension that the front tire on the side that I am jacking is starting to leave the ground before the rear tire has cleared the ground (its clear the front tire will be in the air first).
    Is this normal? Is it safe? I suppose I could always jack the front wheel first and put something under it to mitigate this some, but I am just not sure of the best course. Advice is much appreciated.
  2. Apr 30, 2019 at 3:31 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    It's normal, it's not safe, nothing about the hi lift is terribly safe, I have one for emergency use only. Carry a bottle jack for placement under your rear axle when possible
  3. Apr 30, 2019 at 3:33 PM
    AgingDisgracefully
    Peter
    Yeah, I am wondering if I am going to end up going the bottle jack route for the rear tires.
    ajmogen[QUOTED] likes this.
  4. Apr 30, 2019 at 3:37 PM
    ajmogen
    Aaron
    Wisconsin
  5. Apr 30, 2019 at 3:52 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    You can use a jack mate to lift a wheel a bit easier.
    whatstcp and thedriza like this.
  6. Apr 30, 2019 at 4:29 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    What if he’s changing a rear tire?
  7. Apr 30, 2019 at 4:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    HiLifts look cool on the truck.
    In reality they're dangerous.
    I've had to use mine once and it slipped loose allowing the rear brake drum to hit the ground between someone's legs.
    In a shitty situation they're useful, if not needed. But Jack stands and a regular jack would be safer.
  8. Apr 30, 2019 at 4:39 PM
    eon_blue
    Azusa, CA
    I use my Hi Lift somewhat regularly and I've never had a bad experience with it. The only time I have, was using a friend's Hi-Lift and it was because he never oiled the thing. Hi Lifts should be sprayed down with a dry lube before every use and they won't fail. I've used mine in the snow and it worked fine.
    That being said I think a floor jack is a much more convenient option, if you work on your own truck you should invest in one. Lifting the rear via the rear diff with a floor jack is the ideal method and will lift it easily, since you don't have to max out your suspension travel first. Hi Lift via the sliders means you have to get past the suspension travel before you lift, as you've experienced.
    xxTacocaTxx likes this.
  9. Apr 30, 2019 at 5:16 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Last week I bought one of these bottle jacks. It’s cheap and seems to work, a little slow, not as fast as a floor jack. It has a large base, long adjustable extension and doubles as a jack stand.
    https://www.ebay.com/itm/Powerbuilt...ack-Stand-640912/173839766565?epid=1676575415
    Nitroeye likes this.
  10. Apr 30, 2019 at 5:21 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
  11. Apr 30, 2019 at 5:21 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  12. Apr 30, 2019 at 5:22 PM
    Grossomotto
    2017 4WDV6LB6MT
    No it’s a lot bigger than the stock bottle jack. But you can lock it up in the bed.
  13. Apr 30, 2019 at 5:26 PM
    Grossomotto
    2017 4WDV6LB6MT
    Also worth noting I have a hi lift jack, too. But never have used it, really just for show. I’ll use a floor jack at home and a large bottle jack away if needed.
    Actually, a hi lift makes a great come along if your winch shits out or don’t have one.
    DW85, Miami Chillin and m603holden like this.
  14. Apr 30, 2019 at 5:33 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Get a really strong strap and tie off the rear axle to the frame before you lift your truck - the axle will not travel as far when you lift it.
    ***Make sure it is a good strap- I like to use a tow strap***
    If you wrap it around the axle and frame tightly, the friction of the axle pulling on it will hold it well, especially if you use a double half hitch (clove hitch) knot. When you lower the truck, the strap will come off easily without the pulling from the axle.
  15. Apr 30, 2019 at 5:34 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I carry the OEM scissor and two pieces of cribbing. I jack with the jackmate then slip the scissor in straight and level as a temporary “jackstand”. It is quick and lightweight on the trail solution. And because you support the truck on the well placed jack it is fairly solid.
    Sub_Par[QUOTED] and m603holden like this.
  16. Apr 30, 2019 at 5:56 PM
    OnHartung'sRoad
    Jack stand or appropriate supports like a beer bottle ;) under the axle after he lifts the wheel with the lift mate.
    DaveInDenver and Sub_Par[QUOTED] like this.
  17. Apr 30, 2019 at 6:26 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    You use the lift mate to get the tire in the air and then you shove logs or a jack stand underneath the axle, then transfer the weight over to the jack stand.
  18. Apr 30, 2019 at 6:47 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    You can use a chain for this too, if you have one. I had to do it on my old Suburban because it had so much axle droop
  19. Apr 30, 2019 at 6:50 PM
    OnHartung'sRoad
    As long as one doesn't pinch a brake line with it! :anonymous:
    C-Rok275[QUOTED] likes this.
  20. Apr 30, 2019 at 10:40 PM
    slowtacotruck
    17 offroad
    stuff
    Grossomotto[QUOTED] likes this.
