Hi-lift jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by duckcmdr, Jan 17, 2009.
  1. Jan 18, 2009 at 10:26 AM
    wawireguy
    wawireguy Well-Known Member
    I don't have a specific jack suggestion but I never did like the hi-lift jack I had. Seemed dangerous. And of limited use.
  2. Jan 18, 2009 at 11:14 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I have a 3 1/2 ton floor jack I use at home. Low profile enough for my car, tall enough for the truck. If not, I have blocks of wood laying around. Not that hard.
    Oh, and even if you install a lift, the rear axle doesn't change height unless you change the wheels. Even then if you go up to a 285 or 33" it's only an extra 1.5" so the stock bottle jack should work.
  3. Jan 18, 2009 at 12:25 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I've heard of people using chains, ropes or straps to limit wheel travel so they can get by with a smaller jack. :thumbsup:
  4. Jan 18, 2009 at 5:27 PM
    duckcmdr
    duckcmdr [OP] If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Thats good to know that it hooks into the reciever. I think with all the options you can cuy for these it would be a good tool for offroading. sounds like there are many ways to use the jack. I plan on getting sliders so that will be another option. thx for the info
  5. Jan 18, 2009 at 5:30 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Thanks for all the info on the jack. I made up my mind to purchase one 60" with the option i need. anyone know of any group buy on these.
  6. Jan 18, 2009 at 5:35 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    You go it. Maybe i can learn some tricks on a meet. We need to get one going around these parts.
  7. Jan 18, 2009 at 6:11 PM
    Bill Brasky
    Bill Brasky Well-Known Member
    East of the Mississippi, South of the Ohio
    stump jumper
    modified for light trail use
    We (tigerfan was there too) were lucky enough to watch the Toyota Trail Team do a Hi-Lift demonstration last summer at Harlan. Everything from lifting to spreading to winching techniques. It was pretty cool.
    Of course, I wasn't smart enough to video it. But, yeah, something like that will cover all the bases of owning and using a hi-lift. Might even find some stuff on youtube.
  8. Jan 18, 2009 at 6:31 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I used mine under the ball mount to pick the back end up out of some ruts in the snow when I was buried to the frame. I used the jack's tendency to tip to my advantage. :D Picked the back end up, tipped the jack to an angle, and kept jacking. Base dug into the ground and started pushing the wheels over to solid ground! Reached the end of the jack, reset, did it again maybe 3 times to move the rear wheels over a few feet to solid ground then backed out. :D
  9. Jan 18, 2009 at 6:39 PM
    wawireguy
    Buy a come along and get a safe jack. You'll be loving that thing when you pop yourself in the head.
  10. Jan 18, 2009 at 6:53 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, well, I was in "fuck it" mode. :rolleyes: Wife and kids with me, took a back road that didn't look bad. Just some snow over the dirt road. Then it turned into about a foot of snow with some dirt on it. I found out when the truck sank down to the frame. Tried 4Hi, 4Lo, locker, rocking, and then dug for about 20 minutes while wishing I had a winch kit for the jack before that "pole vault" trick as you call it came to mind. I was actually quit surprised at how well it worked. Took maybe 5 minutes to get out after dicking around for nearly half an hour with the other options.
    Then again, I'm used to just picking up lawn mowers to move over or when stuck so I thought "hey, why not do the same thing here?" :laugh:
  11. Jan 18, 2009 at 7:03 PM
    piercedtiger
    Jon
    Southern Tier, NY
    LMAO :rofl: So true....
    I actually use my jack around the house more...
    1. rope loop under my barn door corner and over hi-lift to pick it up and pop a roller back on the track
    2. tied off like a tripod under my car port with a 2x4 on the lift tongue to push up the canopy to replace a failing brace (left it like that for 3 days until I could fix it without the jack moving)
    3. used it with some blocks to squeeze a lawn mower tire long enough to replace a valve stem
    4. picked up logs so I could cut with my chainsaw (with a loop of rope around the log and lifting tongue, top of jack tied off to 2 other trees)
    These jacks are VERY useful you're smart enough to use them properly, and brace them when necessary.
  12. Jan 18, 2009 at 7:08 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
  13. Jan 18, 2009 at 7:11 PM
    piercedtiger
    Jon
    Southern Tier, NY
    This is a good place for me. :D
  14. Jan 19, 2009 at 9:49 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I went the same route in mounting, but lowered it a little so the cover would close.
  15. Jan 19, 2009 at 9:51 AM
    #35
    Bill Brasky
    stump jumper
    I use quickfists in the factory rails for shovel amd axe holders. I like having things organized where I can just reach in and grab what I want w/o having to unpack everything.
  16. Jan 19, 2009 at 1:45 PM
    #36
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    that looks pretty sweet!
  17. Jan 30, 2009 at 4:09 PM
    #37
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    That thing is badass. It would make self-rescue in soft stuff sooo much faster.
  18. Feb 21, 2009 at 12:21 PM
    #38
    bhelms100
    bhelms100 Member
    Altoona, Iowa
    09 Tacoma TRD 4 DC Speedway Blue
    Started using my jack over 30 years ago. On trucks and tractors. Best jack made here in the good old USA
  19. Feb 21, 2009 at 4:14 PM
    #39
    Bill Brasky
    stump jumper
    As a matter of fact, aren't they made right there in your neck of the woods, bhelms? Or pretty close, anyway.
  20. Mar 11, 2009 at 8:12 PM
    #40
    skynyrd
    skynyrd Member
    denver
    08 taco 4x4 quadcab TRD off road 3 inch lift
    3 inch toytech lift 285/75/16 BFG AT KO
    Do you have any recommendation as to which jack stands would be suitable in that combo for instance when wanting to change a tire on a 3 inch lifted taco while off road using the hilift jack and jack stands.
