Hi lift Jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jakeda, Sep 22, 2015.
  1. Sep 22, 2015 at 10:02 AM
    jakeda
    jakeda [OP] Well-Known Member
    denver
    2015 dbl cab LB
    n/a
    Does anyone know if I need a high lift jack with my 2015 if i have a 2 inch lift ? Just to do a basic tire swap .
  2. Sep 22, 2015 at 10:10 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I don't think you would. But what would you use on your truck to use the jack with? Some bumpers and sliders are meant for them. Our trucks as they sit have no contact points to use them.
  3. Sep 22, 2015 at 10:14 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    ^Listen to him
  4. Sep 22, 2015 at 10:16 AM
    medic2230
    Murph
    Bama! Roll Tide
    Unless you are adding plate bumpers and rock sliders there is no where on a stock tacoma to use one.
    Unchained 5150 likes this.
  5. Sep 22, 2015 at 10:17 AM
    hack4875
    hack4875 1 of 377
    Colorado Springs, CO
    2015 TRD PRO Supercharged
    Negative. I have ~2" lift and my floor jack works just fine.
    agunday21 and jakeda[OP] like this.
  6. Sep 22, 2015 at 10:17 AM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
  7. Sep 22, 2015 at 10:18 AM
    medic2230
    Murph
    Bama! Roll Tide
    Stock jack will too. All you're looking at is maybe at most a 1" difference from the tires to the axle.
  8. Sep 22, 2015 at 10:19 AM
    medic2230
    Murph
    Bama! Roll Tide
  9. Sep 22, 2015 at 10:20 AM
    hack4875
    hack4875 1 of 377
    True. But stock jacks suck. :)
    medic2230[QUOTED] likes this.
  10. Sep 22, 2015 at 10:20 AM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    :anonymous: Just kidding. Was testing you to make sure you were paying attention. Good job you passed the test. Haha I missed the tire swap part. Only read hi lift Jack and then no armor to lift from haha
    hack4875 and medic2230[QUOTED] like this.
  11. Sep 22, 2015 at 10:23 AM
    medic2230
    Murph
    Bama! Roll Tide
    Truer words have never been spoken.
    hack4875[QUOTED] likes this.
  12. Sep 22, 2015 at 10:27 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    What about using the receiver hitch with the hi-lift jack?
  13. Sep 22, 2015 at 10:53 AM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    That would absolutely work if you needed to change one of the rear wheels.
  14. Sep 22, 2015 at 11:27 AM
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    Those jacks are just so dangerous unless you really know what your doing. I'm afraid of them.
  15. Sep 23, 2015 at 10:42 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That's what I have. I take a Jack stand on long trips and on off road excursions. I've test ran the lift in my driveway and can swap out a flat quicker with the hi-lift than the crappy OEM tools provided. And, that's with a clear cab; once, in the field it'a PIA getting the OEM jack out of the truck as I have to clear everything from the seat and floor board. I also bought an extra spare I carry in the bed to speed things up. I've only had a flat in the field once, and I was able to plug it. So, get a good plug kit and you may avoid having to replace the tire all together.
  16. Sep 23, 2015 at 3:49 PM
    Pigpen
    Dan
    Northwest Montana
    X2 on this
    Lift mate is awesome, as long as you are prepared to block the axles (or use a jack stand). I've used this method several times to swap my winter and summer tires.
