Hi-Lift Mounting Bracket kit for 05+ Tacoma Pickup Beds from ATO!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Dec 7, 2012.
  1. Dec 7, 2012 at 8:33 AM
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    These mounts are the best and simplest solution to mounting your Hi-Lift in the bed of your Tacoma. They require NO modifications, NO holes drilled, just a simple bolt on installation. The only tools required are a 9/16" wrench or socket. They hold your jack securely to the side of the bed utilizing the factory track system. They can be adjusted towards the front or rear of the bed, whichever suits you better.
    Kits come with two brackets and all hardware needed for $72.00. Price includes free shipping to all 50 US states, Puerto Rico and Guam. Save $5 each if you order 2-4 mounts or save $7 each when you order 5 or more! To order click here or contact ATO!
    *NEW*: Cross Drilled Bolt Option! Each Hi-Lift mounting bolt is cross drilled for a 1/4" pad lock. Upgrade for just $5 per set.
  2. Dec 14, 2012 at 9:22 AM
    ArmorTech
    Adam
    Our laser shop got a batch of these out for us faster than expected. They are now in stock and ready to ship! Your family could have a great stocking stuffer for you in time for the big day!
  3. Dec 21, 2012 at 4:33 PM
    ArmorTech
    Adam
    We've got these great hilift mounts in stock and ready to ship!
  4. Dec 23, 2012 at 11:03 AM
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Raining outside and it gives me time to wander through the forum on items i need. No doubt about the strength of these, question on the bottom of the bracket.
    Is the any issue with it punching or wearing into the bed? Do I need to put something under it?
  5. Dec 27, 2012 at 7:26 AM
    ArmorTech
    Adam
    No we have not had any issues with that. Keep them tight and they shouldn't be vibrating.
  6. Dec 29, 2012 at 11:14 PM
    JimBCa
    Jim
    Bay Area California
    2012 TRD Off Road
    Thanks, ordering a set
    Ordered
  7. Jan 2, 2013 at 7:31 AM
    ArmorTech
    Adam
    Thank you for the order!
  8. Jan 4, 2013 at 9:56 PM
    JimBCa
    Jim
    Bay Area California
    2012 TRD Off Road
    My set arrived today, packaged very well.
    These are probably the most stout item on my truck and are very well made. Glad I spent the extra to get these. Will paint and install this weekend.
    Will post pics when done
    Thanks again
  9. Feb 5, 2013 at 1:06 PM
    ArmorTech
    Adam
    I've got these in stock and ready for a new home, order yours today!
  10. Feb 5, 2013 at 1:09 PM
    CrAiG
    CrAiG Well-Known Member
    Tacoma889
    2010 toyota tacoma TRD
    Three inch spacer lift
    I wish there was a way to lock it so no one walks off with the jack.
  11. Feb 5, 2013 at 1:15 PM
    ArmorTech
    Adam
    We've had customers drill across the end of the bolt and install a small padlock or cable lock.
  12. Feb 5, 2013 at 1:17 PM
    CrAiG
    Tacoma889
    That's not a bad idea at all!!
  13. May 8, 2013 at 7:31 AM
    ArmorTech
    Adam
    Cross Drilled bolts are now an option for those of you looking to be able to lock your jacks. The option includes both bolts cross drilled to accept a 1/4" shaft lock. This upgrade is $5 and is available on our website now!
    Brackets are back in stock and ready to ship so get yours ordered before you next wheeling trip!
  14. Sep 3, 2013 at 12:03 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Primed and sprayed with bedliner. Worked perfect and still allows use of the tonneau with no problems.
  15. Sep 3, 2013 at 8:40 PM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    Sweet
  16. Sep 9, 2013 at 5:50 PM
    ArmorTech
    Adam
    Kelly, looks great, thank you for sharing!
  17. Sep 9, 2013 at 5:51 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Are we able to order just a cross drilled bolt if we already have the mounts? Wish this would've been an option when I ordered...
  18. Sep 9, 2013 at 6:09 PM
    ArmorTech
    Adam
    Matt,
    Sure we can arrange that. Give me a call and I'll get you set up.
  19. Sep 22, 2013 at 3:38 PM
    CanisLupus
    Stokesdale | NC
    Tried calling multiple times over the last week or two with no luck as well as leaving a message. Any way I can get one of the cross-drilled bolts?
  20. Apr 16, 2014 at 6:44 AM
    ArmorTech
    Adam
    We have plenty of these in stock and ready to ship!
