Hi Lift on a Snowboard/Ski Rack
Discussion in 'Off-Roading & Trails' started by Scubasteve4533, Nov 11, 2011.
  1. Nov 11, 2011 at 6:34 AM
    Scubasteve4533
    Scubasteve4533 [OP] Well-Known Member
    Ohio
    11 TRD OR
    5100 @ 1.75, tsb rear springs with 5100. anytime fogs, rear diff breather, 50 cal ammo boxes on bed rails
    So I have been looking for a way to mount my hi lift, shovel, and a axe in my bed. One of the ideas I thought of was mounting a thule roof rack bar set across the bed and putting a snowboard rack on it. That way I could lock them up and also use it for its intended purpose. My question is has anyone done this before? Is the jack too thick to fit in the rack?
    Thanks in advance
  2. Nov 11, 2011 at 7:05 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I have a Thule ski/board carrier and the "max capacity" for that thing is 2" and thats pushin it.. I'd think the Hi-lift is too think but idk, don't have one of those
  3. Nov 11, 2011 at 9:09 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I think the hi lift is too heavy. there is not enough tension in the thule ski rack to hold it in place in the event of a sudden stop or accident. The jack would not stay put. I thought of trying that too since I have Thule load bars and ski rack. Good idea but not a good solution.
    Mine is pretty simple. I got two exhaust clamps, and used wingnuts instead of the regular nuts. It would be easy to run a small cable with a padlock if you wanted it locked. The exhaust clamps secure it to the Thule bars.
