Hi-Lift or Bottle Jack?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by udrunk2002, Sep 20, 2018.
  1. Sep 20, 2018 at 8:13 PM
    udrunk2002
    udrunk2002 [OP] Well-Known Member
    Hello, I plan on taking my 18' OR on the beach to surf fish. I do not plan on putting on any mods (Tires or rock sliders)...just using the stock set-up. I'm in the process of getting recovery kit, shovel, traction board... I was planning on getting a Hi lift jack...but there really doesn't seem to be much in the way of jack points. They sell a tire strap for the jack but I'm thinking about just going with a bottle jack and board. So what's a better jack for a stock truck?
  2. Sep 20, 2018 at 8:17 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Boards and a bottle jack.
  3. Sep 20, 2018 at 8:19 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Unless you plan on adding sliders and bumpers down the road you may not get much use out of a hilift. Sounds to me like youre already set for beach trips with the traction boards and shovel and a stock jack. You may want to consider an air compressor so you can air down and air back up at the end of your trips.
    tcjacado, Sterling_vH111 and whatstcp like this.
  4. Sep 20, 2018 at 8:20 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    This man is correct
    CaptainBart45 likes this.
  5. Sep 20, 2018 at 8:28 PM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    Which bottle jack would you recommend for 3”+ lift?
  6. Sep 20, 2018 at 8:29 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
  7. Sep 20, 2018 at 8:34 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Air compressor works wonders. Paired with an ARB deflator preferably. Helps in winter too for cold weather members.
  8. Sep 20, 2018 at 8:39 PM
    m603holden
    Marteeen
    New England
    The same bottle jack and 2x4
  9. Sep 20, 2018 at 9:03 PM
    udrunk2002
    i have a 2 gallon air compressor already. Is that too big to use with the 110outlet in the bed? When that compressor kicks on, I gotta imagine it uses a ton of juice. Thanks for the replies
  10. Sep 20, 2018 at 9:07 PM
    Shepherd12
    Shepherd12 Well-Known Member
    Josh
    PA Wilds
    Black ‘18 Pro MT
    KO2’s
    Have you considered an exhaust jack?
    bclark3 likes this.
  11. Sep 20, 2018 at 9:19 PM
    m603holden
    Marteeen
    New England
    udrunk2002[OP] likes this.
  12. Sep 20, 2018 at 9:24 PM
    bclark3
    bclark3 New Member
  13. Sep 20, 2018 at 9:31 PM
    udrunk2002
    That is a nice looking unit. But I have the 110v plug in the bed. Just not sure if my current air compressor would possibly cause any stress or damage to the electrical system
  14. Sep 20, 2018 at 9:31 PM
    josowski
    josowski Well-Known Member
    Justin
    '16 Tacoma TRD Off Road Crew Cab Long Bed
    Nothing yet... Bought it with TWO miles on it!!!
    Plus one on the bottle jack.
  15. Sep 20, 2018 at 9:33 PM
    m603holden
    Marteeen
    New England
    If you can find the manual for it, or sometimes it'll be listed on the compressor itself, look for the amperage draw. And then compare it to what the inverter outlet is on the truck. That will let you know if it can handle it or not. Worse case scenario truck wise you'll pop a fuse. But it could also leave you stranded without air.
  16. Sep 20, 2018 at 9:33 PM
    udrunk2002
  17. Sep 20, 2018 at 9:40 PM
    m603holden
    Marteeen
    New England
    I personally use a standard size bottle jack that can fit all trucks. Stock and lifted. I also carry a good amount of cut up 2x4 for dunage for my truck and other lifted trucks.
    I also have that exact air compressor. Works great. Comes with a nice bag. The biggest thing is all of that gear can be used with my truck or any other truck that may need it. That's where on board air falls short. The 300 just clips to the battery.
    Traction boards aren't a bad idea either. But at least bring some long boards, straps and a shovel.
    Go slow. Be cautious. And have fun.
