Hi-Lift size?
Discussion in 'General Automotive' started by dylandercole, Mar 11, 2010.
which size?
  1. 36''
    0 vote(s)
    0.0%
  2. 42''
    1 vote(s)
    4.8%
  3. 48''
    15 vote(s)
    71.4%
  4. other
    5 vote(s)
    23.8%
  1. Mar 11, 2010 at 4:56 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    What size hi-lift jack do people use with a 3'' lift?
  2. Mar 11, 2010 at 5:07 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    48" Works great.
  3. Mar 11, 2010 at 5:08 PM
    dylandercole
    Dylan
    is that overkill though? once I get my sliders I was a hi-lift but dont want one thats way more than I need
  4. Mar 11, 2010 at 5:10 PM
    rmb_crew
    nah not over kill at all. A 60" is overkill but it good to have the extra lift just in case.
  5. Mar 11, 2010 at 5:30 PM
    dylandercole
    Dylan
    yea makes sense
  6. Mar 11, 2010 at 9:56 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    get the largest you have room for is a good rule of thumb.
    Also depends on what you use it for?
    the 60" is better if you use it for a winch. However, if you only have room for a 48" then get that.
    For example, I have a winch, so do not plan on using it as a winch (though a battery failure could require it). My mounting location is also better suited for a 48" so I got that. however, had I not had a winch, I would probably go with a 60"
  7. Mar 14, 2010 at 9:11 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I voted other becaue I had a 60" that I had to cut off a bit to make it fit in my bed.
  8. Mar 14, 2010 at 9:16 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i choose the bigger one (thats what she said)
  9. Mar 15, 2010 at 9:02 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    60 - Go Big Or Go Home!!! ;) I have the short bed and did not cut mine
  10. Mar 15, 2010 at 9:31 AM
    OSUjake
    OSUjake Dave
    DAVE
    KANSAS CITY, MO
    02 TACO TRD OFF ROAD SR5 4X4 EXT CAB STEPSIDE
    TOYTEC 3" ULTIMATE LIFT / BUD BUILT SKID PLATE / ATX ARTILLERY BLACK RIMS / FIRESTONE AT'S / RHINO BED LINER / KENWOOD RADIO - 4 5X7 SPEAKERS, BLUE TOOTH, XM / U-HAUL TRAILER HITCH / 01 TUNDRA FRONT BRAKES w/DISC ITALIA / BAK BEDRAILS & TAILGATE / BLACK BI-XENON HEADLIGHTS / NEW VALVE COVERS and TIMING BELT / DEBADGED.
    Where can you go and what kind of a 48" jack lift can you get for a 2002 Taco 4X4 ext cab ???
  11. May 26, 2010 at 1:14 PM
    wolfeye
    wolfeye Well-Known Member
    Murph,
    Could I get a pic of the 60 mounted in your short bed please!
