Hi Lift Use - A Coutionary Tale
Discussion in 'Garage / Workshop' started by Jonyd182, Mar 13, 2012.
  1. Mar 13, 2012 at 12:03 PM
    Jonyd182
    Jonyd182 [OP] What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    Good afternoon,
    At first I wasn't going to post this due to my bruised ego but I thought it might serve some other first time users out there.
    So this past weekend I decided to rotate my tires using my welded sliders and my hi lift jack. I was also going to banging out the front fenders for a little more tire clearance.
    So I chock the driver side wheels and use two jack stands while I hammer away and switched the passenger side tires. Everything went well and then it was time to switch sides and lower the hi lift.
    This was the first time the jack has ever had a heavy load on it and it would not lower. After almost 45 mins of lubricating and researching the very simple lowering process I could not figure out why it would not lower.
    Long story short I had to push down on the handle hard to activate the ratcheting mechanism of the jack. As I was not prepared for this specific action/reaction the jack caught me off gaurd and the handle slipped out of my hands.
    This left just open air between the handle of the jack and my head. Wack into the side of the head. 2 days later and a visit to the doctors I'm suffering from a mild concussion. Happen so fast that there was not even a moment that I could have reacted after my hands slipped.
    I watched several video's and read the instructions before using it and from what I can gather; is that a newly coated hi lift jack can cause the pins to stick and in general do not funtion as well as a broken in jack.
    I'm not pointing the finger at anybody but me in this case as I usually seem to find the hardest way to learn something.
    My advice to any other first time users out there is when lowering the jack pull from underneath the handle so that if it does slip out of your hands, you are not in the way.
    :amen:
  2. Mar 13, 2012 at 12:05 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    Glad you're ok, lesson learned!!
  3. Mar 13, 2012 at 12:09 PM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    glad to hear you are ok; is the truck ok too?
  4. Mar 13, 2012 at 12:12 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Good advice, have not had to use mine yet but sounds like something I would do for sure!
  5. Mar 13, 2012 at 12:14 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Shite! I don't trust myself beyond a flat tire replacement.
  6. Mar 13, 2012 at 12:16 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Having to work from home for a couple of days in spurts. Truck is just fine. The jack ratcheted down one notch and stopped. It really could have been a lot worse so I am in no way complaining.
    After screaming many explatives, I did finish lowering the jack and completed the other side of the truck ;)
    If your not familar with using a hi lift, the handled is completely loose when lowering until it ratchet's. Then the full force is transfered into the handle with a violent upward stroke that needs to be controlled.
  7. Mar 13, 2012 at 4:26 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    There's a reason they're called Farmer Killers.
    Good to hear you're doing okay. Can I suggest investing in a hi-lift handle keeper?
    http://www.hi-lift.com/accessories/handle-keeper.html
    That way when you go to switch it from lift to lower, you can be worry free about it slipping and taking your noggin off.
    Other than that, every time I use mine, I am very conscientious about keeping all body parts out of the line of fire in case something happens.
  8. Mar 27, 2012 at 11:48 AM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
  9. Mar 27, 2012 at 11:52 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I do that all the time just practice using it any time you need it. I still need to try out the come along method using it to winch my truck. Have you tried that yet
  10. Mar 27, 2012 at 11:56 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Hi-Lifts are awesome, but definitely something that should be practiced with on a lower-weight target to get used to the concept before going after big game as it were. At least you've still got all your teeth!
  11. Mar 27, 2012 at 11:59 AM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    +1
    I often refer to myslef as a "wrench retard"....
  12. Mar 27, 2012 at 4:48 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    I think that was actually my biggest issues. They Jack behaved differently with a heavy load on it and "stuck" more then I previously experienced with lighter loads.
    Thanks for posting Burke's video. If I had seen that before my attempt I believe the end result would have been a more positive experience for me.
  13. Mar 27, 2012 at 4:52 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    the widow maker strikes again.
  14. Mar 28, 2012 at 10:06 AM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    I haven't tried that yet. What do you need to do it? I forget if they just sell it all in a kit
  15. Mar 28, 2012 at 11:22 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    It is well known that the jack does that. Countless people have been injured and rigs with dented doors. I sold mine in favor of a traditional jack with mounted skidplate.
    I tried to use the jack once to test...under load i ran into the same problem. Too dangerous imo. Didnt want to screw up and have truck fall or get wacked.
  16. Apr 4, 2012 at 10:27 AM
    petyanca
    petyanca Well-Known Member
    Tacoma, WA
    09 AC 4cyl 4x4 5spd
    Seems like its a good idea to wear a helmet while working with hilift. I have a friend who wears ski boots when he mows his lawn, says he is paranoid about blades breaking off or some other crap flying out from underneath the mower.
  17. Apr 4, 2012 at 11:06 AM
    BAMFTACO
    Juan
    Kings bruh
    They sell the attachment it's pretty cool how it works I have it its just I havent used it yet might just do that today
  18. Apr 12, 2012 at 3:04 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Awesome, I'll look into that.
    Lemme know how it goes!
  19. Apr 12, 2012 at 3:08 PM
    tacocolin
    tacocolin Well-Known Member
    Colin
    Cloudcroft New Mexico.
    Kevin's (ATO) bad ass rig he built
    Everything Kevin from ATO did on his... and then some. LOL
  20. Apr 12, 2012 at 3:13 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I dropped my truck onto slick concrete using one. Not good for rotors or dust guards when they go from 2' to slab in less then a second [​IMG]
    lol - I remember when one almost got intimate with your skull at BC.
