Hi my name is John I just bought a 2023 Toyota Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pt046759, Mar 20, 2024.
  1. Mar 20, 2024 at 5:29 AM
    pt046759
    pt046759 [OP] New Member
    JOHN
    2023 TOYOTA TACOMA
    Hi everyone I just bought a 2023 Toyota Tacoma with 15,000 miles on it just noticed that the rear leaf springs are pretty much flat is this a common issue with their generation tacomas anybody know of a recall that replaces the leaf springs or a fix for this.
  2. Mar 20, 2024 at 5:30 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    Pics would help
    and welcome to tacomas.
    It’s perfectly normal the way they look.
    They are extremely soft
  3. Mar 20, 2024 at 5:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome.
    That's probably normal. The springs on the Tacoma tend to look flat when empty, they will be slightly inverted when worn.
    Best way to check is get the truck on the garage floor or other level ground, and run a tape measure from wheel center to bottom of fender, all four corners. The rears on a stock suspension should be 1" higher than the fronts.
    Chew and gilligoon like this.
  4. Mar 20, 2024 at 6:53 AM
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Normal.
  5. Mar 20, 2024 at 7:31 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Welcome to TW John.
    The previous owner of your truck was most likely a stonemason and hauled block and mortar bags for 15K miles...j/k:D
    The OEM rear leaf springs are notorious for being soft/weak, but yours are probably normal, especially considering the low miles on your truck.
    Lots of good info in the Suspension sub-section if you're looking for options.
    https://www.tacomaworld.com/forums/suspension.18/
  6. Mar 20, 2024 at 9:19 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    normal. go to a dealership and look under the new ones.
    Chew and blackZEBRA like this.
  7. Mar 20, 2024 at 9:21 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
  8. Mar 20, 2024 at 9:36 AM
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    They come flat off the production line. I checked mine when it was still on the dealership lot.
  9. Mar 20, 2024 at 9:42 AM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to TW.
  10. Mar 20, 2024 at 9:49 AM
    m(a)ce
    m(a)ce Well-Known Member
    2017 TRD Off-Road Camper
    AluCab Canopy Camper OME Suspension AEV Crestone w/KO2s ARB Summit Bar Warn Zeon 10S CBI Overland aluminum skids CBI sliders Safari Snorkel ARB Intensity lights
    congrats and welcome!
  11. Mar 20, 2024 at 9:50 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    There are pictures and more discussion here.
    https://www.tacomaworld.com/threads...al-for-stock-leaf-springs-pics-inside.761933/
  12. Mar 20, 2024 at 10:06 AM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Wait until you notice the exhaust crossover pipe that is smashed flat from the factory.
