Hi Newbie with 2016 Transmission question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spicoli15, Jun 30, 2022.
  1. Jun 30, 2022 at 3:10 PM
    Spicoli15
    Spicoli15 [OP] Member
    2016 Tacoma Double Cab Limited
    None
    Hello,
    Glad to be here. I bought a 2016 tacoma double cab limited edition right off of a lease back in 2019 and have had zero issues until a few days ago.
    the issue is with the transmission I believe. When I am driving in D mode it seems to make a sound that is consistent when your in a standard and your about to stall.. not sure the word for it but the truck is shaking a bit...
    I feel in S mode it's much less apparent. Wondering if this is a normal issue and what it can be. The truck had 77k on it and like I said no transmission issues other than that and when I go downhill fast it likes to downshift at times which I'm actually ok with.
    thanks for your help and sorry if this has been covered before! Im going on a long family trip soon and want to see what I need to do! Im not a handy guy either lol.
    thanks!
  2. Jun 30, 2022 at 3:26 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Maybe due for a ATF change.
    cbouch001 likes this.
  3. Jun 30, 2022 at 3:27 PM
    Spicoli15
    None
    Like I said I'm not a handy guy. Is that automatic transmission fluid? Thanks man appreciate it
  4. Jun 30, 2022 at 3:29 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's probably retarding timing. mine always acts wonky for a while after every weather change. the ecu is very sensitive to changes....due to the "AI"
  5. Jun 30, 2022 at 3:37 PM
    Spicoli15
    None
    What's retarding timing? How can you fix it? I'm assuming that word was misspelt lol
  6. Jun 30, 2022 at 3:53 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    the ecu retards timing when it detects knocking. the usual fix is to use a higher octane fuel.
  7. Jun 30, 2022 at 3:58 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I would take it to the dealer and ask them to service the tranny if I were you.Also has it had the current TSB for the ecu ?
  8. Jun 30, 2022 at 4:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  9. Jun 30, 2022 at 4:13 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Trans fluid flush, unhook ground cable, clean throttle body, fuel treatment every oil change.
  10. Jun 30, 2022 at 4:29 PM
    cbouch001
    cbouch001 Well-Known Member
    Charlie
    PNW
    2020 SR5 Taco
    OTT Tune, Bilstein 5100 with Icon RTX, SCS F5 , ARB Recovery point, MBRP Exhaust
    The downhill downshift is most likely the dfco (engine braking )
    It’s also what does your engine braking when coasting
  11. Jul 1, 2022 at 1:13 PM
    Spicoli15
    None
    I have not had a TSB for the ECU. Is that like a recall and free or no? I bought it 2019 and so far have only had oil change every 5k miles, front breaks, and back tires replaced. No issues with Tran until a few days ago .
  12. Jul 1, 2022 at 1:22 PM
    TruckGuy63
    Gilbert
    New York
    If It were me I would ask them to do a drain and refill and at the same time ask them to do the ecu update for your tranny tell them you’ve always had erratic shifting and didn’t know there was a TSB .They should flash it for free and at the same time they will reset all the values . Also with the drain and refill you will have fresh fluid running through the system which at 70 k is a good thing
  13. Jul 1, 2022 at 2:44 PM
    Spicoli15
    None
    So I need to bring it to a dealer now. I was gonna bring it to a private shop but if I might get some stuff for free May need to bring it to a Toyota dealer
  14. Jul 1, 2022 at 2:57 PM
    TruckGuy63
    Gilbert
    New York
    I believe that may be the way to go . I hope all works out for you
