Hi steer hitting spring pack
Discussion in 'General Tacoma Talk' started by BruceBrannon, Nov 2, 2024.
  1. Nov 2, 2024 at 2:14 PM
    BruceBrannon
    BruceBrannon [OP] New Member
    Sas 01 tacoma
    Sas
    Just asking for some general information on an SAS Tacoma the high steer is hitting the spring pack. There’s a shim on the passenger side. Was wondering if I could remove that and was considering drilling new holes and inch back on the spring perch to push the axle about an inch forward, so I can get the part of the leafspring that’s flat any help would be much appreciated
  2. Nov 3, 2024 at 1:33 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Huh? No idea what you are talking about but welcome to TW.
    JFriday1 and BruceBrannon[OP] like this.
  3. Nov 3, 2024 at 1:35 PM
    BruceBrannon
    Sas 01 tacoma
    Sas
    I have a solid axle conversion on my 2001 Tacoma. I went to put the high steer on and the arms are lower than the spring packs so the arms would rub. I was wondering if there was any solutions or spacing to stop the steering linkages from hitting the top of the spring pack
  4. Nov 3, 2024 at 1:55 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Maybe a picture? What axle, what knuckles, what steering, what springs, etc? There are lot of variables. Does it hit all the time or just when at full turn? Does it hit on one side or both sides?
    BruceBrannon[OP] likes this.
  5. Nov 4, 2024 at 8:36 AM
    BruceBrannon
    Sas 01 tacoma
    Sas
    I’ll get pics soon the front has 53 inch front springs on an 1985 Toyota front solid axle and I’m trying to install trail gear high steer I will get pics asap thank you for the reply it’s that links rubbing the top of the springs
