HID ballasts mounting
Discussion in 'Lighting' started by 113tac, Feb 26, 2011.
  1. Feb 26, 2011 at 8:51 AM
    113tac
    113tac [OP] Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    Alright so I just got put some HID's on and i thought it'd be a good idea to make a thread for people some pics of where people mount their ballasts. I searched and couldnt find many pictures on where people were mounting their's.
    So let's see em!
    ill post a pic in a little when i go take some
  2. Feb 26, 2011 at 11:04 AM
    tencrawler
    tencrawler I'm a lover not an expert
    Wes
    Petaluma
    1985 Pickup 4x4 SCLB 22R 5SPD Manual
    Only 55K Original Miles in Spring of 2018
    I like the idea of this thread. I'm not particularly happy with the placement of my ballasts for my Headlights or Fogs. I actually need to reinstall one of the fog ballasts (replaced through warranty) and I was considering rewiring and relocating my HID set ups. Looking forward to getting a few ideas.
  3. Jun 13, 2016 at 12:51 PM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    Pics?
  4. Jun 13, 2016 at 1:58 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I would take pictures but i have mine exactly where andrew put his.
  5. Jun 13, 2016 at 2:07 PM
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    And you just use 3M tape? I did that for an install years ago and it failed. But it seems like everyone's go-to now. Maybe it's a better product now?
  6. Jun 13, 2016 at 4:36 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    I used the industrial strength velcro at walmart. Works great for me. You can probably use zip ties or screws to screw it down
  7. Jun 14, 2016 at 2:53 AM
    113tac
    Stephen
    Northern Virginia
    No, I can't find any, I went back to regular bulbs a few years ago haha
  8. Jun 14, 2016 at 3:46 AM
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Cool. Can I ask why? Had u installed retros or just rolled HIDs in halogen housing?
  9. Jun 14, 2016 at 4:22 PM
    113tac
    Stephen
    Northern Virginia
    They were in the stock housing. After I adjusted them so I didn't blind people they weren't that great. A bulb burnt out and I just never felt that replacing the bulb was worth it haha
  10. Jun 18, 2016 at 4:13 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Here is where I put my TRS ballasts. Can't really tell, not that great of pictures.
  11. Jun 18, 2016 at 4:13 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I'll get better pictures tomorrow
  12. Jun 19, 2016 at 5:17 AM
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Sounds good, thank!
  13. Aug 10, 2016 at 4:36 AM
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    What kind of screws? Just self-tapping metal screws? Even tho it's a bad picture, I assume u couldn't get a wrench behind it.
  14. Aug 10, 2016 at 10:23 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yeah self tapping screws. They're mounted on the sheet metal between the engine bay and the fender. So the other side is inside the fender. It holds tight though! I mounted the controller right in front of the ballast that you see there. The hardest part is getting a wrench or socket on the headlight adjustment screws. I use a 4mm socket on the adjustment screw w/ an extension
  15. Aug 13, 2016 at 6:13 PM
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    I have just purchased all the parts and new headlight assemblies to do a conversion to the Morimoto D2S V3.0 and I too am looking for locations that people have used for placement of the wiring harness and more importantly the ballasts. I was pretty sure I read that some folks attached the ballasts directly to the headlights using double sided tape or velcro. I would like to see any photos or suggestions on where this stuff was placed. I'm pretty anal about a clean looking installation so I may need to take apart the inside of the engine compartment to make it look nice and like factory, if that is possible. I was really hoping for a much simpler wiring harness without power connections to the battery.
    So tomorrow I will split my new headlight assemblies apart and I will take a lot of photos. I will also take photos on my placement and what I used to do the installation. I'm not doing anything fancy, keeping it all chrome looking, no halos or LED lights added (I would like to add a nice bright string of LED lights to the inside to make DRL but I'm not sure what LEDs would be appropriate).
  16. Aug 13, 2016 at 6:21 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    image.jpg There is a perfect flat spot on the side of the gen2 headlight housing for ballast. Fog ones and Hella retros are both mounted on the top and sides of the aluminum crash bar. All are mounted using 3M dual lock. With this it actually snaps into place, but can be removed if needed.
  17. Aug 14, 2016 at 5:45 AM
    JoeSchmuck
    Joe
    Virginia
    Are you talking the large flat spot in the inside (vehicle center line) next to the larger amber bulb? That was the only really good place I could see. I'd love to mount it with three screws but it appears the small screws would come right through the inside reflector area. Also I can see the velcro would facilitate easy access the the bulb should it need to be replaced.
  18. Aug 14, 2016 at 7:14 PM
    TacomaArto
    Wisconsin
    2015 White DCSB SR5
    Figured I would jump in now and show where I decided to mount things.
    For the controller I bent top 90 degrees and drilled a hole, then used #10 screw and lock nut vinyl washer.20160814_160849.jpg 20160814_160822.jpg
    For driver side ballast I snuck it in on the side by the battery. Started by using industrial velcro, but added a self-tapping metal screws for fun. Never going anywhere.
    And for passenger ballast I drilled a hole and again used a #10 screw and lock nut nylon washer.
    Pretty happy with it all. May take some slack out of all the leads someday if I am bored enough. Just to tidy it up some more.
    TRSJimmy likes this.
  19. Aug 17, 2016 at 6:28 PM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
  20. Aug 20, 2016 at 10:56 AM
    brightshizzle
    brightshizzle Well-Known Member
    Nashville, TN
    2012 Tacoma, TRD, DCSB, 4WD
    Following
    TacomaArto likes this.
