HID bi-xenon help!!!
Discussion in 'Lighting' started by newskooler, Dec 28, 2010.
  1. Dec 28, 2010 at 5:02 PM
    newskooler
    newskooler [OP] Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    ok so installed my new kit bi-xenon slim ballast Hid kit and it was pretty damn simple. all was well for the twenty minutes that i drove my truck for the test drive i then parked it in my garage for the weekend.
    the problem came a couple of days later when i tried to turn them on with no success. it blew my RH Hi and RH Low fuses. i installed new fuses and they also went.:mad: i checked all connections and tried switching the ballasts and nothing.
    ive deducted through my limited knowledge that its a RH side ballast is the problem(right?) but would that cause the LH side to also not to work? any suggestions/ideas? ive contacted the seller but he was busy and promised to call me back. till then do you guys have any ideas?
  2. Dec 28, 2010 at 6:07 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Try a different ground? Check that the High/Low modulator/relay does not have water in it.
  3. Dec 28, 2010 at 8:02 PM
    newskooler
    Nick
    Lake Shastina,ca
    ok so on a side note when i was putting everything back to where it should be. i noticed a humming noise and located at this box. the goes inbetween the factory head light plug and then to the ballast
  4. Dec 28, 2010 at 8:04 PM
    gpend5.7sport
    gpend5.7sport Well-Known Member
    Gabe
    Houston
    2010 Toyota Tundra TRD Sport
    too damn many
    those ballasts look they are made out of plastic dude
  5. Dec 28, 2010 at 8:14 PM
    newskooler
    Nick
    Lake Shastina,ca
    heres what the whole thing looks like. i put an arrow on what is making the noise. its some kind of regulatory device for the power supply??? im about as eletrically inclined as toddler with a fork and an electical socket
  6. Dec 28, 2010 at 9:10 PM
    gpend5.7sport
    Gabe
    Houston
    too damn many
    eh idk about all that other junk on that kit but my ddm kit has a ballast and a bulb with connections lol 40 bucks and it still is a great kit but mine is a tundra idk about older tacos
  7. Dec 28, 2010 at 9:26 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    That box doesn't look common...
  8. Dec 29, 2010 at 4:57 PM
    newskooler
    Nick
    Lake Shastina,ca
    Bump anybody got an idea?
  9. Dec 29, 2010 at 9:15 PM
    newskooler
    Nick
    Lake Shastina,ca
    no heat but i did smell something that resembled arc welding so i unhooked the battery and removed the setup from my truck. my conclusion it that the box has either a wiring issue or it somehow go condensation in it from sitting in my garage:confused:
  10. Dec 29, 2010 at 9:42 PM
    newskooler
    Nick
    Lake Shastina,ca
  11. Dec 29, 2010 at 11:34 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
  12. Dec 30, 2010 at 12:25 AM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    You'll hear horror stories on anything. Nothing is perfect. Welcome to the real world, unless you don't want to enter it.
  13. Dec 30, 2010 at 12:49 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    did you try bigger fuses i know mine said to use at least a 20 i dunno might help
  14. Dec 30, 2010 at 12:50 AM
    outxider
    outxider Well-Known Member
    Sang
    Bay Area
    06 DCSB 4x4
    A few mods here and there and counting....
    I ordered approx 8 sets of HIDs from ddm tuning and out of those 8, one had a bad ballast, which they replaced, and another set came w a bad relay for the bi xenon setup. i would still buy from them because its the best deal you can get.
  15. Dec 31, 2010 at 10:50 AM
    newskooler
    Nick
    Lake Shastina,ca
    Finally heard from tim yesterday. He's ordered a new set and they will hopefully be here soon.
    I definitely agree good customer service is always better than price 3 of the last 4 items I've bought have been defective or missing parts and tims been really good about taking care of the situation.
    Just a an example a certain company sent me the wrong bolts in november and I just received the them today 12/30. You would think that they would expedite three shipping in those situations
