HID Bulb going out need help
Discussion in 'Lighting' started by awoit, Feb 9, 2010.
  1. Feb 9, 2010 at 6:31 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    When i turned my headlights on tonight i noticed my drivers side headlight (HID) turns on dim for a quick second and then goes out completely.. does this mean that i need a new bulb or could there be a connection problem?
  2. Feb 9, 2010 at 6:32 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    check the fuse
  3. Feb 9, 2010 at 6:32 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Check your connections, but it sounds like a ballast problem.
  4. Feb 9, 2010 at 6:33 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    mine done that for a bit but on the passenger side. it turned out that it was my ballast. the ballast burnt up and i had to get a new one. it was under warranty. if its not too hard then put the passenger side ballast on the bulb and see if it still does it then if it does it will pretty much have to be your bulb
  5. Feb 9, 2010 at 6:35 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    just switch the ballasts around and you'll know if it's the ballast or the bulb
    Edit: haha. what he said^
  6. Feb 9, 2010 at 7:09 PM
    awoit
    CA
    08 TRD, SR5
    alright guys i switched the ballasts and the same sides out so i guess its the bulb.. anyone know a cheap place for a replacement 35W 6K ? .. i thought these bulbs were suposed to last longer than a year lol
    p.s that picture above me is crazy!
  7. Feb 9, 2010 at 7:13 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    DDM tuning.
  8. Feb 9, 2010 at 7:16 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    check your ground before you go buying new bulbs.
