HID conversion advice needed.
Discussion in 'Lighting' started by Rolltide1, Aug 21, 2016.
  1. Aug 21, 2016 at 9:05 AM
    Rolltide1
    Rolltide1 [OP] New Member
    2016 Grey TRD Off road
    Can anyone help me with some advice on what direction to go with HID's. I believe there are 2 wattage choices for ballasts? Which is better 35 or 55? Thanks for any input!
  2. Aug 21, 2016 at 9:11 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    35 is very bright, probably equal to 130 watts of halogen light. Unless you are a racer in Baja, you don't need more watts.... but hey, if you want to to have the most, it is available!
    The more important factor is COLOR TEMPERATURE!
    Around 5,000° is WHITE and the most light. Going to 6000° or more makes blue light, and that is less bright. Some like the blueish tint for looks... but seeing is more important, isn't it?
    A few years ago I posted several photos of my HID lights with 5,000° and 6,000° units (both 35 watt).
  3. Aug 21, 2016 at 9:21 AM
    Rolltide1
    Thank you for the reply. I agree with the bulb color for driving safety. I'm not a huge fan of too much blue.
  4. Aug 21, 2016 at 10:54 AM
    snowbrdd
    snowbrdd Well-Known Member
    If you are truly concerned about driving safety, make sure you do a proper projector retrofit. Regardless of what wattage you use, no retrofit is unsafe while a retrofit is safe. Color temperature above 6k is unsafe in any normal driving application, retrofit or not.
    t4daddy likes this.
  5. Aug 21, 2016 at 10:57 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    x2 what is said above.
    Putting an HID into our housings will cause you to be "that guy" on the rode who's blinding everyone. I typically flip my light bar on for those sumsabitchez. If you want HIDs, do a proper retrofit, or buy the premade retrofits on here. There's one guy on here who's "cheap" and they run about $500.
    t4daddy and Sicyota04 like this.
  6. Aug 21, 2016 at 12:47 PM
    David K
    My reply was considering HID as auxiliary off road lamps, not converting our factory headlights. Might as well go straight to LED and skip over the few years that HID was the name of the game! LED turns on instantly, HID takes several seconds to reach full brightness. That is why they make for poor high beam use, as when you flip from low beam to high beam... the light will be dimmer for a few moments.
  7. Aug 21, 2016 at 10:44 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Retros shouldn't be needed in the 2016 projectors, however as others mentioned I'd look at fanless LEDs over HIDs.
  8. Aug 22, 2016 at 4:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, good observation. Didn't realize his was a '16
  9. Aug 22, 2016 at 5:02 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    If you are considering HID's I would go with Morimotos. They are the best plug and play with reliable and REPLACEABLE components. I would like to see how the LEDs work out for you though.
    Coot
  10. Aug 26, 2016 at 6:50 PM
    CaptainMorgan
    CaptainMorgan Custom headlight retrofits
    Mesa, Arizona
    2014 White Tacoma TRD Sport
    17 inch Black Rhino Rockwell Wheels, BFG 275/70/17 Ko2 Tires, 3 Inch Rough Country Front lift 2 inch Rough Country Rear Lift
    The wattage difference depends on what kind of bulbs and lights you want to run. If youre just doing a standard retrofit then just go with the 35Watt ballasts
