HID Flicker
Discussion in 'Lighting' started by thebigsmit, Mar 16, 2013.
  1. Mar 16, 2013 at 6:14 PM
    thebigsmit
    thebigsmit [OP] Well-Known Member
    Brent
    South Carolina
    2013 Tacoma TRD Off Road
    3 inch Toytec lift, Westin E series bull bar, HID/Halo retrofit, sway bar disconnect
    I just installed my mini d2s kit I got from the trs group buy. They are 55w 6000k morimoto bullbs. After they warm up for a while something starts flickering. Its almost like a piece of dust on the bulbs that move except it only happens once they warm up. I have cleaned the bulbs with alcohol multiple times.
  2. Mar 16, 2013 at 6:15 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    check your grounds?
  3. Mar 16, 2013 at 6:15 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    X2 on grounds.
  4. Mar 16, 2013 at 6:23 PM
    thebigsmit
    Brent
    South Carolina
    I have both my grounds set to the frame where other grounds bolt on. I didnt really explain myself very well. Its not the whole beam that flickering just a part at the very top at the most concentrated area.
  5. Mar 16, 2013 at 6:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    did you try cycle the high/low? could it be the shield twitching?
  6. Mar 16, 2013 at 6:36 PM
    thebigsmit
    Brent
    South Carolina
    Yep did that multiple times. Flickers on high beams too. It really stumps me on why its doing this.
  7. Mar 16, 2013 at 7:08 PM
    battlescars
    battlescars Professionull1
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Bad ground, bad power connection, crappy ballasts.
  8. Mar 16, 2013 at 7:35 PM
    thebigsmit
    Brent
    South Carolina
    They are morimoto 5five ballasts. Shouldnt be low quality. Thanks for the suggestions ill check the grounds and power later.
  9. Mar 16, 2013 at 8:23 PM
    thebigsmit
    Brent
    South Carolina
  10. Mar 17, 2013 at 12:36 AM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    Perfect example of how aftermarket kits have problems regardless of brand.
    I'm so sick of seeing everyone say that TRS has the best quality kits an all this BS. They're just overpriced kits IMO
  11. Mar 17, 2013 at 12:52 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    After getting my HID conversion (of Hella Halogen 4000 lamps) done by that guy in Orange County, and going through the months of hassle to get the right color, ballast that doesn't blow up, etc. I posted here about the flicker as seen in your video... I described it as the look of a candle flame in a light breeze, and not an on-off flick of the light switch.
    So, you are not alone, and my HIDs still work after 2 years, although I rarely use them (rarely drive at night and no money to go desert camping lately)!
  12. Mar 17, 2013 at 1:10 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I have the 3five d2s kit from TRS and it does the same thing as posted in your video. My grounds are solid with 14 gauge wire, soldered and shrink wrapped and all my connections are solid so I know it's not a wiring issue. Mine did this from day one along with a long warmup time. I believe its the hardware I got from TRS.
  13. Mar 17, 2013 at 1:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Mine doesn't do that, but my right high beam sticks.
  14. Mar 17, 2013 at 1:38 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    op, are you using a projector?
  15. Mar 17, 2013 at 1:41 PM
    dexterdog
    Oly WA
    2012 F150
    I see your op says mini so there goes one of theories. I would get a hold of TRS and or visit hidplanet.
  16. Mar 17, 2013 at 1:44 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Rich check out my build thread for my retro, I had the same problem and fixed it. I have pictures of what I did.
  17. Mar 17, 2013 at 1:48 PM
    thebigsmit
    Brent
    South Carolina
    Good to know im not the only one. Personally, it just looks like the bulbs to me but Im definitely no expert.
  18. Mar 17, 2013 at 1:49 PM
    dexterdog
    Oly WA
    2012 F150
    Where was that said anywhere in this thread? Get over it.
  19. Mar 17, 2013 at 1:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mine was just fine for 2 months, then suddenly stuck one morning, and it's been sticking ever since. I can flick the highs repeatedly and it'll finally drop, but not something I want to do on the road.
    I'm going to just unplug the sticky one for now.
  20. Mar 17, 2013 at 1:58 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Mine does that as well. Kind of annoying, but I've learned to live with it!
