HID flickering?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sighless, Jan 19, 2011.
  1. Jan 19, 2011 at 1:49 PM
    Sighless
    Sighless [OP] Well-Known Member
    TORONTO
    10 SR5
    Hey just a quick question, to everyone with HID's..
    Did you guys need the anti flicker harness for your setup?
    Ive got a 2010 Tacoma, and a local HID dealer here says i need the anti-flicker harness.
    Can anyone confirm this?
  2. Jan 19, 2011 at 1:49 PM
    Sighless
    TORONTO
    10 SR5
    thanks in advance
  3. Jan 19, 2011 at 1:51 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    i needed it, but i'm running 55W
  4. Jan 19, 2011 at 1:51 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    no its a safety precaution. mine still fuckn flicker/cut out. pro: bright lights that get u flashed all the time, cons: they dont always both light up
  5. Jan 19, 2011 at 1:52 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    i saw a mustang when every time they hit a bump it flickered i thought it was funny
  6. Jan 19, 2011 at 1:53 PM
    Sighless
    TORONTO
    10 SR5
    so do the lights actually cut out? or do they just flicker once in a while?
  7. Jan 19, 2011 at 1:55 PM
    CopDoctor
    08 335i
    both.
  8. Jan 19, 2011 at 1:55 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I had 35 watt kit that started to flicker every now and then on start up. I replaced the bulbs and didnt have any more problems
  9. Jan 19, 2011 at 2:07 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    You're a douche for blinding people and thinking it's a "pro". There's a reason you get flashed. HID's in reflector housing are retarded. If you're going to do HID's do it the right way or aim your light down so the hot spots aren't shinning at on coming traffic.
    35 watt kits also need a harness. The start up draw on 35 and 55 watt ballast is higher than the rating on the stock harness. Some people get away with the stock harness and some burn the wiring up.
    I don't know why people call it an anti-flicker harness when it's just a regular harness that does nothing for flickering. You're ballasts most likely flicker because they're poorly made and cheap.
  10. Jan 19, 2011 at 4:06 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    Finally somebody that has experience with HID. Everytime I tell people to run a seperate harness for HIDs even plug and play kits, people think i'm dumb or crazy. A seperate harness with direct battery power will be more reliable and your output will be significantly better.
  11. Jan 19, 2011 at 4:17 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Photo bellow is 35 Watt Apexcone Raptor Kit from DDM Tuning for my fogs
    Been there done this! If you don't want your Hids to flicker...
    1. Order from DDM Tuning http://www.ddmtuning.com/Product-Categories/HID-Kits-Lighting
    2. Purchase the Battery Wire Harness (35 or 55 watt kits)
    3. Make sure you have true grounds
    I got hosed for $100.00 on a Hid kit from another source and no matter what I did they flickered
    My Raptor kit from DDM Tuning has been perfect:) No Flicker once so ever!
  12. Jan 19, 2011 at 4:24 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I got the 55w apexcone kit from DDM tuning. No flicker, no harness, and no blinding people PERIOD .
  13. Jan 19, 2011 at 6:01 PM
    CopDoctor
    08 335i
    can you run those in traffic? or too bright?
  14. Jan 19, 2011 at 6:05 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I too have always recommend that people run a relay harness as well regardless of what wattage the kit is. The stock wiring ISN'T made to handle the increased voltage draw an HID kit pulls when the ballasts first start up. Definitely cheap insurance to not risk frying your stock wiring.
  15. Jan 19, 2011 at 6:28 PM
    PrerunnerChris
    PrerunnerChris Go Big Or Go Home!
    SoCal
    06 PreRunner V6
    is the harness you are talking about the dual in dual out for like 13 bucks or something like that? Or are u talking about High / Low kits come with a fused relay harness and controller that regulates the high / low operation.
  16. Jan 19, 2011 at 6:48 PM
    blazze2005
    South Jersey
    I can run them in traffic,but I don't do it out of respect to other drivers
    I have been flashed once in 6 months since I have installed them
    I save my HID Fogs for the back roads when I need them
    I'm talking about the Relay Wire Harness in the link below
    http://www.ddmtuning.com/Products/HID-Kit-Wiring-Harness
