HID fog lamp ballast locations?
Discussion in 'Lighting' started by NelsonTacoma, Jul 5, 2012.
  1. Jul 5, 2012 at 7:12 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    So, I'm getting ready to install HID's in my fog lamps. Not sure where to mount the ballasts though. Where is everyone mounting the ballast? I thought about double sided tape to the back of the bumper cover but don't trust it to hold them up. Any pictures or suggestions would be appreciated. :)
  2. Jul 5, 2012 at 7:15 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    When I had my stock bumper I mounted them with zip ties to the vent looking things in the fender liner.
    When I got the Relentless bumper it freed up some space to zip tie them right below the headlights.
  3. Jul 5, 2012 at 7:49 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Stock bulbs also don't have any sort of glare shield, so they blind other drivers as well. HIDs are only brighter, so blind a wee bit more.
    My fogs are actually angled out to the sides instead of directly in front of me for maximum flood lighting in front of the vehicle, also helps with cornering in dark areas due to tint.
  4. Jul 5, 2012 at 7:53 PM
    NelsonTacoma
    Tucson, AZ
    I thought about zip ties but worry about the longevity of them. Zip ties get brittle after a few years. Maybe use the bigger ones?
    Good idea. I wonder if they have extreme double sided tape too?
    I used double sided tape for my headlamp ballasts but they are on top of the fenders by the battery and washer bottle, so they won't fall down quite so easily.
  5. Jul 5, 2012 at 8:01 PM
    NelsonTacoma
    Tucson, AZ
    I love duct tape until you have to remove it.
    The ballasts have a plastic mounting bracket with holes for screws so I could run the zip ties through them. But I also wonder if that would cause them to bang around and possibly induce early failure?
  6. Jul 5, 2012 at 8:09 PM
    NelsonTacoma
    Tucson, AZ
    No problem. Thanks for the ideas!:cool:
  7. Jul 8, 2012 at 3:47 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    even the 3m auto double sided tape will hold up fine, ballasts are real light, and if u want to make sure, just add a few zip ties to some of the plastic clips under there
