HID fog lights stop working
Discussion in 'Lighting' started by emerson, Jan 2, 2010.
  1. Jan 2, 2010 at 3:54 PM
    emerson
    emerson [OP] Well-Known Member
    seattle
    offroad
    I installed some HIDs in the fogs. They stopped working!!! Last night i noticed that only the driver side worked. So this morning I went and checked the connections on the passenger side. Still nothing, but this time it started flickering. So i tried turning the switch on and off, now both sides dont work. Try installing a relay? I dont know where to go from here now. So any input would be great.
    Thanks!
  2. Jan 2, 2010 at 4:01 PM
    pikegi
    pikegi Well-Known Member
    Brandon
    South Carolina
    09 WHT LB DC TRD Sport 4X4
    I had the same problem before and reconnecting the ground fixed mine. You may also want to check the positive connection also!
  3. Jan 2, 2010 at 4:05 PM
    emerson
    seattle
    offroad
    Thanks for the quick reply. Are you talking about the ground from the kit into the factory connector? Tried that. Went and checked the fuse and it was blown changed that still nada. Now only the driver side work, still getting a buzzing and flickering on the pass. side.
  4. Jan 3, 2010 at 5:40 AM
    pikegi
    Brandon
    South Carolina
    Dang, my only other guess would be to check the wiring harness that came with the kit. Maybe a loose wire!
  5. Jan 3, 2010 at 5:43 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You are getting a buzzing and flickering- Sounds like it could be a bad ground or a bad ballast.
  6. Jan 3, 2010 at 2:47 PM
    emerson
    seattle
    offroad
    Went to the DDM website for some help. They suggested switching bulbs and ballast. So i did that and the bulb still works on the left side, still nothing on the right side. A few trys later it blew the fuse. Replace the fuse blew another. So i said screw it and put in the stock bulbs. So yeah sounds like its a bad ballast.
