HID Fog lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bdwsrjoe, Mar 2, 2010.
  1. Mar 2, 2010 at 9:41 PM
    bdwsrjoe
    bdwsrjoe [OP] Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    Are HID fog lights illegal? I've been getting alot of people flashing their high beams at me after installing them?
  2. Mar 2, 2010 at 9:46 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Nope, did you make sure they are installed correctly with the reflector shield down? I remember reading a thread about that on an install or something to that effect. Probably just not used to seeing such a bright ass fog light. Also how lifted are you or do you have the bro lean?
  3. Mar 2, 2010 at 9:48 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    HIDs are meant to be used in a projector with a cutoff. You may have to fabricate some kind of cutoff to stop the random dispersion of light causing blindness of oncoming drivers.
  4. Mar 2, 2010 at 9:48 PM
    bdwsrjoe
    Joe
    Rio Hondo, TX
    my headlight HID's came with a shield and i installed those correctly, but the fogs didn't come with a shield? im running a 3 inch lift.
  5. Mar 2, 2010 at 9:50 PM
    ToucanV13
    x2 sounds like your solution. Either that or just use them for inclement weather
  6. Mar 2, 2010 at 9:53 PM
    bdwsrjoe
    Joe
    Rio Hondo, TX
    Can a cop give me a ticket for this?
  7. Mar 2, 2010 at 9:55 PM
    dually
    dually Low and slow
    Most likely not.
  8. Mar 2, 2010 at 9:59 PM
    bdwsrjoe
    Joe
    Rio Hondo, TX
    I didn't think so, i've never heard of anybody getting a ticket for bright fogs but ya neva know.
  9. Mar 2, 2010 at 11:20 PM
    ToucanV13
    Then again, if you're severly blinding other drivers, you could get a ticket for hazardous operation of a veh IIRC. Best to look up TVC (texas vehicle code). I'm a cop in the Navy and I tell you what, I'm not sure about TX, but CA seems to have a CVC for everything. Just my .02
  10. Mar 2, 2010 at 11:54 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Although law enforcement should have better things to do, actually Yes you can get a ticket for that. In Texas where you live there are two penal code statutes that concern the appropriate use and installation of fog lights:
    Statute 547.328. FOG LAMPS PERMITTED.
    (a) A motor vehicle may be equipped with not more than two fog lamps.
    (b) A fog lamp shall be:
    (1) mounted on the front of the vehicle at a height
    from 12 to 30 inches; and
    (2) aimed so that no part of the high-intensity portion of the beam from a lamp mounted to the left of center on a vehicle projects a beam of light at a distance of 25 feet that is higher than four inches below the level of the center of the lamp.
    (c) Lighted fog lamps may be used with lower headlamp beams as specified by Section 547.333.
    Statute 547.333. MULTIPLE-BEAM LIGHTING EQUIPMENT
    REQUIRED.
    (a) Unless provided otherwise, a headlamp, auxiliary driving lamp, auxiliary passing lamp, or combination of those lamps mounted on a motor vehicle, other than a motorcycle or motor-driven cycle:
    (1) shall be arranged so that the operator can select at will between distributions of light projected at different elevations; and
    (2) may be arranged so that the operator can select the distribution automatically.
    (b) A lamp identified by Subsection (a) shall produce:
    (1) an uppermost distribution of light or composite
    beam that is aimed and emits light sufficient to reveal a person or
    vehicle at a distance of at least 450 feet ahead during all conditions of loading; and
    (2) a lowermost distribution of light or composite
    beam that:
    (A) is aimed and emits light sufficient to reveal a person or vehicle at a distance of at least 150 feet ahead; and
    (B) is aimed so that no part of the high-intensity portion of the beam on a vehicle that is operated on a straight, level road under any condition of loading projects into
    the eyes of an approaching vehicle operator.
    (c) A person who operates a vehicle on a roadway or shoulder shall select a distribution of light or composite beam that is aimed and emits light sufficient to reveal a person or vehicle at a safe distance ahead of the vehicle, except that:
    (1) an operator approaching an oncoming vehicle within 500 feet shall select:
    (A) the lowermost distribution of light or composite beam, regardless of road contour or condition of loading; or
    (B) a distribution aimed so that no part of the
    high-intensity portion of the lamp projects into the eyes of an approaching vehicle operator; and
    (2) an operator approaching a vehicle from the rear
    within 300 feet may not select the uppermost distribution of light.
    (d) A motor vehicle of a model year of 1948 or later, other than a motorcycle or motor-driven cycle, that has multiple-beam
    lighting equipment shall be equipped with a beam indicator that is:
    (1) designed and located so that the lighted indicator is visible without glare to the vehicle operator; and
    (2) lighted only when the uppermost distribution of
    light is in use.
  11. Mar 2, 2010 at 11:59 PM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    3 inch toytec, magnaflow exhaust, KNN intake, URD MAF, HID 55 watt, Hella 500 HID, Smoked tail lights LED running lights, Pioneer deck with 8 inch infinity sub, Focal 165VB and 165CVX with JL 320/4, Tinted all around 3%, Tinted interior lights.
    They are illegal in California. I got pulled over for my head lights and my fogs! The sheriff told me that they are starting to make a law for HID's specially. But its aftermarket like the tacoma dont come stock with HID's so its a ticket. But on the other hand like a crystler 300 has stock HID's not a ticket. Its 25 for a fix-it ticket now and the sheriff told me the ticket for the off highway lights (HID's) will be more than $100.
  12. Mar 3, 2010 at 1:01 AM
    ToucanV13
    Fight it until they have the HID cvc unless it's a code like above
  13. Mar 3, 2010 at 3:41 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Damn, they don't give y'all a break on anything in Cali... Guns, intakes, engine mods, now fog lights and aftermarket HID's??
  14. Mar 3, 2010 at 4:10 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    In my opinion, if you are driving around with hid fogs, blasting all of your fellow motorist as they drive by then you deserve a ticket. A foglight like what comes on the Tacoma is not designed to utilize a hid bulb. All you end up doing is dispersing light every which way you can imagine.
  15. Mar 3, 2010 at 4:40 AM
    AzogSS
    Andy
    Soda City, SC
    Some stock Silverado fog lights are blinding without HID's, what should be done in that case?
  16. Mar 3, 2010 at 7:30 AM
    Kyle
    Kyle Mckeown343
    Arcata
    05 PreRunner
    The thing is i was out at my local desert and was on the dirt road heading back to the freeway with all four of my 55 watt HID's on. The sheriff pulled me over as soon as i hit the pavement. He said he could see me from 4 miles away and that if i have HID's in my fog lights then they have to be covered?? He was a weird guy. I was just polite and told him yes sir i bought the truck like this. lol still gave me the ticket though :(
  17. Mar 3, 2010 at 7:43 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Ok, I don't get it. Why would anyone want HID fog lights? There are basically 2 types of aux lights - fog lights and driving lights. They are 2 different things. Driving lights have a long range, with a "pencil-type" beam, made for seeing a long ways down the road. Fog lights have a low, wide, and short range beam, for literally going under the fog, along the roadway, and for seeing well to the sides of the vehicle. They are designed for slow speed use.
    Fogs should only be used in the FOG. They create glare when combined with rain, as they reflect off shiny pavement. Generally speaking, unless you live somewhere that heavy fog is a usual occurence, fog lights are pretty stupid to have. Why they put them on vehicles as nearly standard equipment, baffles me.
    Driving lights, on the other hand, are useful. Generally they are illegal if used in combination with high-beams. They are supposed to be used only with low beams in MOST places. (I wire mine to work WITH high beams, but I figure I'm only using them when no one is in front of me anyway... in 40+ years of using driving lights, this has worked great.)
    So, my bottom-line opinion is, fog lights are stupid and why anyone would try to make them brighter by putting in HIDs is beyond me. They will just create monstrous glare most of the time. If you want HIDs, combine them with DRIVING light lenses (or off-road lights). They'll be useful there. (Off-road lights are a totally different animal and shouldn't be mounted down low like fogs though - different subject.)
    Then again, I don't get the craze for turning on fog lights anyway. You don't look any more "cool" than any other time, and you just piss people off, which doesn't do any of us any good.
    There. That's the way it is. :)
  18. Mar 3, 2010 at 7:51 AM
    bdwsrjoe
    Joe
    Rio Hondo, TX
    I guess ill just keep turning them off when somebody flashes me........
  19. Mar 3, 2010 at 7:56 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    If people are flashing you, they're likely aimed too high. Adjust them down a bit. Just point the truck at a garage door and bring them down just a little, equally. Not hard. There are adjustments on the back of them.
  20. Mar 3, 2010 at 8:25 AM
    jusmac
    jusmac Well-Known Member
    I currently do the R&D for PIAA corp. usa and yes they are illegal and yes you can get a ticket. any HID that is not factory installed in the united states is illegal. alot of companies get around selling them here by saying "for offroad use only" and such. Either way you will probably not get a ticket depending on where you live but, yes there are illegal.
