HID foglights blew a fuse. Help.
Discussion in 'Lighting' started by Lexxx_2011, Dec 13, 2011.
  1. Dec 13, 2011 at 10:06 AM
    Lexxx_2011
    Lexxx_2011 [OP] Active Member
    South Mississippi
    2011 DC TRD Off-Road Magnetic Grey
    I installed HID's in my fogs a while ago, and now they stopped working. So I put all the halogen bulbs back in and I took it to toyota and they replaced a fuse. So everything works fine with the halogen bulbs. Now, I went to install the passenger side HID back in and it worked. Then I installed the driver foglight and turned on the light switch and Im guessing it blew the fuse again. So now both don't work again. The ballast that blew the fuse has gotten a bit of water in it before, so maybe it blew the fuse cause it is water damaged? Need help, I really want my foglights to start working again, thanks.
  2. Dec 13, 2011 at 10:07 AM
    Harleyfx69
    Harleyfx69 Well-Known Member
    They already work with factory components..
  3. Dec 13, 2011 at 1:56 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    when I have installed HID's in the past, I have always taken the light fuse and whatever amp rating it is, I have replaced it with something 5amps higher.
    I was told that HID's use less wattage, but more startup amperage.
    Dont take that as gospel though.
  4. Feb 21, 2012 at 9:43 AM
    Aw9d
    Aw9d That one guy
    Az
    I ran across this in a different car.. Cheap chinese knock off HID kit would short when mounted with a screw into the frame.. I told the person to have it swapped.. He wrapped it all in electrical tape and zip tied it. He's been running it like that for years now without issues.. I wouldn't suggest that method but it could be why your blowing fuses.
  5. Feb 21, 2012 at 9:48 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'd be careful with this, you don't want to allow more juice than the wires can handle to go through the fuse. You're right about the HID startup though, they have a large initial draw when turned on, then run at lower wattage.
