HID Group Buy...Details inside
Discussion in 'Group Buys' started by slimsdepot, Sep 9, 2008.
  1. Oct 6, 2008 at 6:51 PM
    #161
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I guess I could always cut off the connectors and just splice the wires together. I do have some quick splices and liquid electric tape. Slim, would this void any sort of warranty?
  2. Oct 6, 2008 at 8:19 PM
    #162
    TacoCo
    Colorado
    So, I decided to splice them... Both headlights are working, except the high beams aren't working on the driver's side where I had to splice. I'll have to look at it later.
    I went for a quick spin and got flashed 3 times by passing cars :(
    Now that I think about it, I think the spliced headlight is stuck on high beam... the cut off on the drivers side is higher than the passenger side on low beams and the cut off looks about even with the high beams on.
    And I may have just figured that problem out... when I took the bulb apart to stick it through the housing, I apparently didn't put it back together right. I think that should fix it. Thanks for following along while I think out loud here :D
  3. Oct 7, 2008 at 9:11 AM
    #163
    slimsdepot
    slimsdepot [OP] slimsdepot.com
    SoCal
    08 PreRunner
    Lol TacoCo I like reading your replies and notice that they get answered by yourself eventually. I wish I could have gotten back to you sooner before you spliced because any ballast etc that isn't working can be replaced free of charge under the warranty. But now that you have altered them I am not sure if my supplier would take it back (i might be able to get him to if you still need to replace the ballast but no guarantees).
    As for everyone else if you have any issues please message me first and wait for my response so that I can get you accurate advice as to what you should do. I am usually pretty quick at replacing any parts that were defective most of the time same day delivery out.
  4. Oct 7, 2008 at 9:12 AM
    #164
    slimsdepot
    SoCal
    08 PreRunner
    I am thinking of doing another GB for all the PM's that were after the close of this one and if anybody that only got the headlights were interested in getting the fogs this time.
  5. Oct 7, 2008 at 9:18 AM
    #165
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm happy to wait a month or two before the next group buy. I'd like to see some long term reviews on them.
  6. Oct 7, 2008 at 9:21 AM
    #166
    slimsdepot
    SoCal
    08 PreRunner
    This was my 3rd GB totaling over 150 kits sold in the past 4-5 months. I am planning on doing 1 more and probably stop for a while and work on my company getting bigger. (pool service company)
  7. Oct 7, 2008 at 9:23 AM
    #167
    Hotdog
    Hotdog
    Wet Okole Underwear
    How many complaints have you received about the ballasts quitting after use?
    The new group buy will be offering the digital ballasts, right? What is the difference between the old and the new ballasts?
  8. Oct 7, 2008 at 9:29 AM
    #168
    slimsdepot
    SoCal
    08 PreRunner
    The difference is size they both are excellent ballasts and do the same thing. But one is much smaller, lighter and will be a little more expensive. The next GB will have options for either ballast.
    I have probably had to replace about 10 ballasts that were dead on arrival. Other than that I haven't received any PM's with ballasts dying after install.
  9. Oct 7, 2008 at 9:38 AM
    #169
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    When will be the next GB? I was about to buy some HIDs but were only for the low. and it was already 140. Saw that these were bixenon for 100! thats a steal. WHEN WhEN WHEN!! :thumbsup:
  10. Oct 7, 2008 at 3:28 PM
    #170
    Tail Gunner
    Tail Gunner Well-Known Member
    Kitsap, Washington
    2005 PreRunner SR5 TRD
    Aries black Bull Bar, K&N 63-series Air Intake, HID 6000K Headlights and Fogs, Redline Hood Struts, Kenwood DPX-502 headunit, JDM black headlights, black Altezza tailights, Bracketronic I-pod mount, and several more audio mods to come Debadged
    Has anyone else had a problem with the H10 kit fitting in the foglight. I thought it was going to be a quick install, but for some reason I can not get the bulb to turn in the holder. It looks like the part where the gasket is at is just a RCH too big around to fit in the hole.
  11. Oct 7, 2008 at 4:46 PM
    #171
    TacoCo
    Colorado
    Well, I think I figured out why I was blinding everyone that I passed last night... The bulb on one side wasn't fully retracted from the housing when the low beams were on. It was sitting further back, like when the high beams are on, so I essentially had one headlight on high and one on low. I pulled the bulb assembly out of the headlight and pulled the bulb as far out as it would go, and it seems to be working ok now... how long it holds up, who knows.
  12. Oct 7, 2008 at 5:57 PM
    #172
    slimsdepot
    SoCal
    08 PreRunner
    I would say in about a week and I will post a link in this thread to the new GB thread so if you are subscribed to this one you'll get an email on it.
  13. Oct 7, 2008 at 5:59 PM
    #173
    slimsdepot
    SoCal
    08 PreRunner
    You are the first to have this problem from my GB's and can't decipher what could be the problem... what temperature bulb did you get? If I have an extra pair left over I will swap you them out it could be a possible mismatch in size. Let me know so I can help you out.
  14. Oct 7, 2008 at 6:24 PM
    #174
    deadbolt
    deadbolt do w3rk!
    Socal
    Sweet. I see that there is an option for a slim ballast. how much would that be with the low/high beam one
  15. Oct 7, 2008 at 10:03 PM
    #175
    slimsdepot
    SoCal
    08 PreRunner
    I will have the prices once I get all the details from my supplier. They will be anounced at the time of the new GB along with photos etc.
  16. Oct 8, 2008 at 10:35 AM
    #176
    Tail Gunner
    Kitsap, Washington
    I got 6000K H10s
  17. Oct 8, 2008 at 10:52 AM
    #177
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I had a helluva time fitting my fog lights into there hole.
  18. Oct 9, 2008 at 12:02 PM
    #178
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    Just curious, but if these bulbs burn out, can we buy replacements?
  19. Oct 9, 2008 at 12:36 PM
    #179
    Infinus
    Infinus Well-Known Member
    Indiana
    08 Tacoma Double Cab SB TRD Sport
    How do people like this setup in bad weather (ie: rain, snow, etc...). I put HID's on a previously vehicle only to end up blind when it rained.
