HID Headlight kit.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Warhorseforever, Nov 4, 2011.
  1. Nov 4, 2011 at 9:16 AM
    Warhorseforever
    Warhorseforever [OP] Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    If you have HID's pleas share with me what it is that you have. I'm planning on doing mine soon and I've looked at the ddm tuning lights but I'd like to have that clean cut off at the top. Anyone that had done a retro, does you light scatter all over the place or do you have that cut off at the top? Can I do a retro and it still have the cutoff or do I need to buy a new Lens/Headlight assembly? Thanks for your help in advanced!
  2. Nov 4, 2011 at 9:18 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
  3. Nov 4, 2011 at 9:24 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  4. Nov 4, 2011 at 9:28 AM
    Warhorseforever
    Will
    Sand Lapper
    I just saw and started reading up on the links you put on the other guy's thread. I drove a friend of mine's Scion TC a while back, he wasn't in the state to be driving, and now I'm jelly of his and want my own.
  5. Nov 4, 2011 at 9:30 AM
    Warhorseforever
    Will
    Sand Lapper
    The "How often do..." thread btw.
  6. Nov 5, 2011 at 8:28 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    theretrofitsource.com
    mini d2s kit
  7. Nov 5, 2011 at 10:08 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Is there a lot of work involved in getting those in the stock housing?
  8. Nov 5, 2011 at 10:17 AM
    AsianAnts
    AnT
    in a nutshell, bake to separate, aim (FX-r) and install projectors, bake, seal, install on truck and aim
  9. Nov 30, 2011 at 5:57 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Do 1st Gens headlights come apart the same as 2nd Gens? For some reason I thought they had to be cut apart rather than just baked.
    Nvm, they do come apart by baking, they're just a PITA to put back together because of the big hole you have to cut in the back for the projector.
    http://www.toyotanation.com/forum/showthread.php?t=392421
  10. Nov 30, 2011 at 7:38 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    1st Gen headlights were changed every few years.
  11. Nov 30, 2011 at 7:49 PM
    Warhorseforever
    Will
    Sand Lapper
    Thanks for the interest and answers but I think I'm going to put these on. They claim that all you have to do is pull the lights apart and remove the refactor(the peice that covers the bulb as stock, I think it's called that) and put it in, reassemble. I think that I will paint the chrome parts black because eventually I want to go to a Silver/Black 2 tone paint. Black fender flares, black on the rocker panels no higher than the little indentation on the side of the doors, black bumpers, and toolbox.
    http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=250911901845&viewitem=&vxp=mtr&afsrc=1
    Thread that got me into it.
    http://www.tacomaworld.com/forum/deals-coupons/183173-projector-retrofit-kit-160-a.html
