HID Help
Discussion in 'Lighting' started by DPCardoza, Jan 26, 2013.
  1. Jan 26, 2013 at 7:06 PM
    DPCardoza
    DPCardoza [OP] Well-Known Member
    Yuba City
    06 PreRunner Sport Long Bed
    2 problems that i need a hand with
    1. Installed hid fog lights and they turn off when i use my high beam. No recolection as to whether or not it did this before, but i just noticed.
    2. Installing a new H1 retrofit and have no high beams. They dont turn off, just dont go to high. Switched the blue and white wires on the input per instructions but its still a no go. Any other ideas?
    Darren
  2. Jan 26, 2013 at 7:12 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Factory function of the fog lights will turn them off when the high beams are turned on. With HID's, I'd do the fog light anytime mod so they stay on when the high beams are cycled so as not to wear out the ballast and bulbs quickly.
    As for the high beam issue, you might have a stuck solenoid. Did you confirm that the solenoids cycled properly before you sealed them up?
  3. Jan 26, 2013 at 7:25 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    I'm curious to see why they're stuck on low. Sub'd
  4. Jan 26, 2013 at 7:28 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    when you say retrofit you are meaning you bought projectors for your headlights correct?
    Interesting enough when I installed my morimoto h1 projectors i no longer lose fogs when i turn my high beams on
  5. Jan 26, 2013 at 7:29 PM
    Pugga
    Massachusetts
    Also, check to see if your high beam fuse is still in tact, not blown. Double check all your connections, make sure everything is hooked up correctly, all fuses in tact and that you're getting power to all the places that you should. I would guess that the solenoid is frozen. I had a similar issue with my H1 projectors.
  6. Jan 26, 2013 at 8:39 PM
    DPCardoza
    Yuba City
    Unfortunately no I didnt check before sealing them. For what its worth, neither headlight highbeams are working. I tested the lights before sealing them, just didnt think of checking highbeam function. :mad:
    This is the H1 morimoto kit from theretrofitsource.com
  7. Jan 27, 2013 at 12:18 PM
    DPCardoza
    Yuba City
    How do you troubleshoot a stuck solenoid? Everything else checks out fine.
