HID hi/low question
Discussion in 'Lighting' started by donovan6241, Mar 3, 2011.
  1. Mar 3, 2011 at 1:14 PM
    donovan6241
    donovan6241 [OP] Well-Known Member
    Donovan
    San Diego
    2017 TRD Sport Double Cab Long Bed
    someone just installed HIDs on mi truck. He told me that with the hi/low kit my hids will work on the lows only, the high beam will be like stock with no HID, just regular light. And he said with just the low kit when high beams will not work at all. is this true? or did i just get ripped off?
  2. Mar 3, 2011 at 1:20 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Yea on the 2nd gens the hi and low beams are the same bulb and it telescopes out for hi and retracts in for low. (as explained above)
  3. Mar 3, 2011 at 1:27 PM
    donovan6241
    Donovan
    San Diego
    dam. i just wasted $110. the low kit is HID, but when i pull the high beam it is not HID .. its like stock :(
  4. Mar 3, 2011 at 2:22 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What did you buy? It sounds like you got one of those angel eye headlight kits with an HID installed for the low beam and a halogen for the high beam.
    If you bought a plug and play HID Bi-Xenon kit or similar and plugged it into the stock housing, you'd only have HID lights, there wouldn't be a halogen bulb.
  5. Mar 3, 2011 at 9:02 PM
    donovan6241
    Donovan
    San Diego
    the guy that installed it said it is a hi/low kit but with the hi beam is halogen like you said. he told me the one with HID high beam is $50 more. and yes i think it is plug and play- because he did not wire anything to the battery and it took him like 5 min.
  6. Mar 3, 2011 at 9:03 PM
    donovan6241
    Donovan
    San Diego
    whats the difference between plug and play and when you wire it to the battery?
  7. Mar 3, 2011 at 9:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  8. Mar 3, 2011 at 9:21 PM
    donovan6241
    Donovan
    San Diego
    he didnt drill anything. it literally took him 5 min.. to install both lights. he showed me there is one bulb for the hid low and the other bulb is for the halogen. they are both small and looks something like this: http://www.google.com/imgres?imgurl...1t:429,r:21,s:0&tx=106&ty=80&biw=1600&bih=626
    i will post some pics tommaro
  9. Mar 3, 2011 at 9:23 PM
    donovan6241
    Donovan
    San Diego
    ok cool. thanks for the info man. now i know what hid projector retrofits look like, but whats the difference between them and HIDs like i have?
  10. Mar 3, 2011 at 9:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    ahh I see. Yeah, with those there is no high-beam HID. Technically they're not bi-xenon (theres no way for the xenon bulb to move, and theres no added xenon arc for the high) rather than just HID lows and halogen highs.
    It's up to you if that's what you wanted or not, depending on how much you use your high beams and what you need them for. $110 seems a little steep though...
    Edit: Sorry, I may have been wrong on the need for drilling
    hope this helps
