HID High beam help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TacomaLimited, Jan 5, 2015.
  1. Jan 5, 2015 at 4:53 PM
    03TacomaLimited
    03TacomaLimited [OP] Active Member
    Conner
    Tuscaloosa
    2017 DCSB SR5
    None as of yet
    Ok so i got this hid kit from dd tuning and got the hi/lo kit and i hooked it all up and my high beams won't turn. What the fix for this?
  2. Jan 5, 2015 at 5:50 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    dose it come with a set of wire harness?
    if do, did you hook up the red wire to the battery, and the black go to the ground?
    if do that already, check the fuse.
  3. Jan 18, 2015 at 10:43 PM
    Phred
    Phred New Member
    California/Nevada Border
    2010 4x4
    All Pro front bumper SnugTop shell Thule rack
    I just bought an 2010 which seems to have some unknown brand of HID retrofit into OEM H4 socket base in stock halogen light housings. Low beam in strong white light, high beam just generates an unfocused very weak yellow beam. I will check as in above and read as many other related posts trying to learn HIDs and a new forum.
    Anyways if anyone knows my problem help would be appreciated. Thanks.
  4. Jan 19, 2015 at 2:52 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Pictures of lights?
    Edit: read again. Don't think you're talking about projector retrofits. Just an hid kit in the stock reflectors. Correct?
  5. Feb 7, 2015 at 8:42 AM
    ndtemple417
    ndtemple417 New Member
    Spartanburg SC
    2002 quad cab taco
    I have an 02 and just ordered a kit from them was wondering if you figured out the issue just incase i run into this issue thanks for your time
