HID high beam problem!!! Suggestions needed!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clankey, Apr 5, 2010.
  1. Apr 5, 2010 at 10:10 AM
    clankey
    clankey [OP] Well-Known Member
    St. John's, NL
    2010 Double Cab TRD Sport
    Roof Rack, Soft Tonneau, Running Boards, DDM HID's, Skid Plate, 3" lift, 275/70R17 BFG AT TA's
    I jsut installed a set of DDM H4 kit and h10 fog kit. They all work great with the exception of the high beam. When I switch on the high the light is really dim and not even close to the low beam. I am wondering if I should try taking off the metal shield on the bulb?
    Anyone have the same issue or have a good suggestion?
  2. Apr 5, 2010 at 10:15 AM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Glendale, AZ
    I just had an issue with my high beams, but mine was a blown fuse.... check the wiring again.....
    do your HID bulbs have a separate light on them for the high? or is it bi-xenon all in one bulb?
  3. Apr 5, 2010 at 10:22 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    DO NOT take off the metal housing on the bulb!!! You will blind the hell out of other drivers and get pulled over for sure.:eek: I remember someone telling me that when I put in my HID's but I wanted to see for myself anyways and took the housing off. Yeah..I drove like 50 feet and was like, screw that!!! Went straight back to my garage and put the pieces back on.
