HID Install How To (For ambiguous retrofit)
Discussion in 'Lighting' started by thegreatwall23, Dec 10, 2012.
  1. Feb 21, 2013 at 10:04 PM
    #41
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Relay (5-pin) between the switched source and the halos.
    Connect the switched source to 30 and the halos to 87a (insulate 87).
    Connect the low beam to 85, ground 86.
    When the headlights are on, it'll open the relay contact.
    They'll come on with the high beams... you could wire yet another relay identically using the high beam to 85 (both relays in series), or you can connect both the high and low beam wires to the same relay by running through a pair of diodes so they don't backfeed.
  2. Feb 24, 2013 at 5:15 AM
    #42
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Awesome.......tempted to do another retro.....
    Rich, do u think tapping into the side markers would cause premature halo death since when i disarm the truck, the side markers blink twice, stay on till the key is inserted into ignition then they turn off.
    .....then if its nightime ill be turning lights on, thus activating halos. Pretty much 3 cycles right there if its dark :(
    Plus a cycle when the truck is armed.
    (i ordered my truck with aftermarket alarm and don't know if they all do this)
  3. Feb 24, 2013 at 7:16 AM
    #43
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    That's my concern too, premature failure of the LED Halo's...currently I have mine wired to my fog lights but I am considering re-wiring them to my original plan -- to the DTRL so they will run 24/7 and also blink with the turn signals. DATSIK has his wired this way for at least a few months and he hasn't had any issues.
    Also -- for the issue with the HALO relay harness from TRS. Got word that they will be fine without the harness. The harness would be a great option for those who want the HALO's to come on with the headlights, they have a harness that will power them off the HID ballasts. Essentially plug and play with no cutting of stock wires to achieve HALO's on with the headlights.
  4. Feb 24, 2013 at 12:34 PM
    #44
    Rich91710
    Rich
    Los Angeles
    08 Base
    LED halos are not a problem.
    You can strobe those 24/7 and they'll survive.
    It's the CCFL halos that you don't want to flash.
    Arming and disarming the keyless?
    I'm not going to say that it's GOOD for the CCFLs, but I don't think it's going to significantly shorten their life unless you're running deliveries and other activities where you are constantly locking and unlocking the truck.
    Personally, I would tie into a switched ignition source and call it good. They'll act as DRLs during the day and shut off with your headlights at night if you don't want them on (I see no reason to shut them off at night).
    When I was referring to killing CCFLs in only a couple of days, this was with them connected to a traffic signal controller that was constantly cycling, 2-10 seconds on, maybe 30 seconds off. Some survived 24 hours, some made it to 48, but when we hit 48 and had more than 50% failure, it was obvious that CCFL was not the proper product for the application and we moved to an LED product.
  5. Feb 24, 2013 at 5:51 PM
    #45
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Going to rewire my HALO's to my DTRL/turn signals then :D Thanks!
  6. Feb 24, 2013 at 7:34 PM
    #46
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    My TRS kit came with splitters that would allow me to run the halo's off of the ballasts when the headlights came on. I asked TRS what was needed to run them off the parking lights because I wanted the Halos on all the time. They suggested the 9006 relay harness and also stated it was needed to maintain warranty, true or not I still think the relay harness was worth the 25 bucks.
    So basiclly it wired up like this:
    1. Halos' go straight to the 2 relays. There is a ground wire on each end where the halos plug into the harness. I just put those where I grounded the projectors.
    2. Power wire directly to the battery.
    3. Input wires then got Ttapped into the parking light harness.
    Poof! Halos come on full time with the key on.
    Now mind you that I have a 2012 and the DRL's and parking lights are always on...i'm not sure how it works for other model years.
    What I like about this installation is that I only had to tap into the truck wiring harness at one location. The halos will also disconnect at the connectors from the relay harness when the lights need to be removed.
    It just seems to be the right way to do it.
    I like that other than the truck controlling whether the lights are on or off the power for the projectors and halos is 100% controlled thru TRS provided equipment.
  7. Feb 24, 2013 at 7:51 PM
    #47
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I still may go this route, $25 isn't much money. I got the info on the halos not requiring the harness from a TRS retailer, who talked to Trs direct. They will not void your warranty if you run without the harness. I clipped the connectors off my halo wires already so I'll have to come up with something if I go with the trs harness
  8. Feb 24, 2013 at 10:14 PM
    #48
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Thank you sir..... +1 to ya, when I get to my PC
    I knew I could count on ya for help
  9. Feb 25, 2013 at 11:19 AM
    #49
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    You do not need a separate harness to maintain warranty on the LED halos per Matt @ TRS.
  10. Feb 28, 2013 at 7:05 AM
    #50
    rs5
    rs5 TACOLIFE
    Tampa, FL 33578
    05 DC PreRunner SR5 V6 TRD Off-Road
    K&N Air Intake
    Sub'd for future mod
  11. Feb 28, 2013 at 12:33 PM
    #51
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    :thumbsup: Okay, now how do you wire them up so that they also turn off while the turn signals are on? If you go the one relay route, what kind of rating do you need on the diode? are they rated like wire gauge and fuses? I don't know much about diode.
    Thanks
  12. Feb 28, 2013 at 8:12 PM
    #52
    Rich91710
    Rich
    Los Angeles
    08 Base
    Diodes are rated for current and voltage.
    50v is a pretty standard minimum. They don't draw much... you'd be fine with a 5a rating (fuse it at 4a or as close to 4 as you can get).
    Off with the turn signals? Can't make them go off and stay off without a time delay circuit, but you can add another diode from the turn signal hot and have them flash off with the turn signal so they'll go back and forth... almost a wig-wag but only one side. Don't do this with CCFL... only with LED.
  13. May 16, 2013 at 5:56 PM
    #53
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    thats sick man i like it!
    i want to do it to mine
    so bad!
    are RED Halo / Demon eye's illegal?
    my truck is Radiant red
  14. Aug 30, 2013 at 11:55 PM
    #54
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
  15. Sep 15, 2013 at 9:51 PM
    #55
    fenderpicks
    fenderpicks Well-Known Member
    Hey OP, can u remove the rubber gasket that covers the bulb and take a picture of it.
    I am having a hard time figuring out how to modify mine to make the connector fit onto the bulb
  16. Sep 15, 2013 at 11:23 PM
    #56
    Rich91710
    Rich
    Los Angeles
    08 Base
    Just cut the center open enough to clear the D2S connector... or TRS sells rubber "domes" that will fit the housing and allow you to cut a small hole and stretch it enough for the connector to pass through.
  17. Sep 16, 2013 at 5:22 AM
    #57
    thegreatwall23
    thegreatwall23 [OP] Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Yep, exactly what he said above.
  18. Sep 16, 2013 at 8:18 AM
    #58
    fenderpicks
    I tried cutting the stock one.
    But I made the hole too big, so I'm afraid moisture will get on from the big gaps.....
    What size rubber should I get from TRS?
  19. Feb 26, 2014 at 3:28 PM
    #59
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    Is there a reason why my high beams aren't working?
  20. Jul 31, 2014 at 10:23 PM
    #60
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    Subs for an install soon. Hopefully I can I'll this wiring halos to dtrls off with out any hiccups kinda nervous
