HID ISSUE!!!! NEED HELP!!!
Discussion in 'Lighting' started by CrazyCooter, Mar 24, 2012.
  1. Mar 24, 2012 at 3:50 PM
    CrazyCooter
    CrazyCooter [OP] Hold My Beer!
    Johnathan
    Virginia
    I bought a HID setup on here and then accidentally cracked one of the bulbs. So i found another kit on here so i could replace the last kit. The first kit came in an awesome wiring harness setup and was neat and easy to install and figure out and was 35W. The kit i got to replace it it not the same there are nowhere near the same amount of wires and it is not as easy to figure out how to install considering they are totally different. The second set is 55W. The first kit had a ground wire for each light, a power wire going to the battery with inline fuse attached and a connector that hooked up to the stock headlight wire harness. The second kit does not have the power wire for the battery, nor a ground for each light, or a connector for the stock harness. There are 2 male quick connects coming from each ballast and i have no idea where they go. Can someone please share their knowledge with me and help me out. Thanks. The first pic is the first setup and the second pic is the second setup i got.
  2. Mar 24, 2012 at 4:00 PM
    CrazyCooter
    Johnathan
    Virginia
    bump anyone?
  3. Mar 24, 2012 at 4:01 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I'm pretty sure those male connector plug into you stock wire harness . I'll try and find the diagram .
  4. Mar 24, 2012 at 4:01 PM
    CrazyCooter
    Johnathan
    Virginia
    thanks man i tried it but it didnt seem to work for me.
  5. Mar 24, 2012 at 4:06 PM
    johnnym
    john
    NH
    That second kit is the fog lights not headlight
  6. Mar 24, 2012 at 4:09 PM
    CrazyCooter
    Johnathan
    Virginia
    i was afraid of that. So i guess i need to find a replacement bulb for my first set up and it seems like i now have a HID fog light kit. Thanks man.
  7. Mar 24, 2012 at 4:10 PM
    CrazyCooter
    Johnathan
    Virginia
    anyone know the best place to get a replacement bulb?
  8. Mar 24, 2012 at 4:18 PM
    johnnym
    john
    NH
    No problem .
    I get all my stuff from http://www.theretrofitsource.com/
  9. Mar 24, 2012 at 4:29 PM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    You can try there or I get my stuff from HIDDirect.com. great customer service as well
  10. Mar 24, 2012 at 4:52 PM
    CrazyCooter
    Johnathan
    Virginia
    Thanks for the help guys. so are yall for sure they are for fog lights. i pm'd the guy i bought them from and he is saying that he is pretty sure they are for the head lights. So i asked him how he them wired...
  11. Mar 24, 2012 at 7:11 PM
    Hii
    Hii Well-Known Member
    Post a pic of the base of the bulb only. I will be able to tell you the bulb size for it and what it fits
  12. Mar 27, 2012 at 8:30 AM
    CrazyCooter
    Johnathan
    Virginia
    i got everything worked out thanks again guys.
