HID Issues
Discussion in 'Lighting' started by cdn_bacon, Feb 7, 2012.
  1. Feb 7, 2012 at 2:35 PM
    cdn_bacon
    cdn_bacon [OP] Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    I purchased and installed HID's on both my main lights and fog lights 2 years ago. Parts were purchased here on TW in the group buy. LOVE the lights. However a couple days ago I noticed one of my lights is out. Specifically when I turn my lights on this one particular light flashes but then goes off (it never comes on fully, just a flicker and black).
    Think its the ballast? Anyway to fix it?
  2. Feb 7, 2012 at 2:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Same thing happened to my passenger side fog light. Comes on but cuts out sometimes here and there and not sure why. Quick way to check would be to swap bulbs to make sure its the ballast and not the light bulb itself. I still have to do this test to but IMO, it sounds like its the ballast.
  3. Feb 7, 2012 at 2:45 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    This ^^.
    Whenever I had HID problems, I would swap bulbs/ballasts to make sure everything in the system is still functioning. Obviously check your wiring and make sure there's nothing cut/getting cut.
  4. Feb 7, 2012 at 6:35 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Best fix is to install high-efficiency halogen bulbs and drop the HID. :)
  5. Feb 9, 2012 at 3:33 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    usually is the HID bulb problem, no big deal, just purchasing another set HID bulb, and you will be ready to go.
