HID kit for sale $30
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by nj636, Dec 9, 2012.
  1. Dec 9, 2012 at 3:23 PM
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    9003 low beam 35watt 6000K
    plug n play 10 minute install
  2. Dec 9, 2012 at 3:27 PM
    PCHearn
    PCHearn Well-Known Member
    Patrick
    Moore, OK
    11 PreRunner SR5
    Will these work on a 2011 Tacoma?
  3. Dec 9, 2012 at 3:30 PM
    nj636
    Kev
    Jersey
    yes, 9003 bulb.
  4. Dec 9, 2012 at 7:42 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    you say plug and play. does the kit just replace the stock bulb and add a ballast with a factory type connector?
  5. Dec 9, 2012 at 9:41 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    yes
  6. Dec 10, 2012 at 10:42 AM
    nj636
    Kev
    Jersey
    yes
  7. Dec 10, 2012 at 10:55 AM
    LBFD2005
    LBFD2005 Its tha Southern Way
    MS
    11' Trd 4x4 6" pro comp
    procomp 6'' catback dual exhaust flowmaster 44 series
    so is this just the low beams?? which HID bulb is the dual beam?
  8. Dec 10, 2012 at 10:57 AM
    Aw9d
    Aw9d That one guy
    Az
    The high beams (if you get bulbs that have them) will be halogen and they are worthless. Once you add HID's to stock housings there is no need for high beams.. The scatter from the HID's is more of a high beam then a low beam anyways.
  9. Dec 10, 2012 at 11:04 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    just my thoughts, highbeams are always good to flash people, whether to let them in and other stuff, i only got low beams too, cause i was cheap and never really use high beams either, but sometimes nice to have
  10. Dec 10, 2012 at 11:06 AM
    LBFD2005
    MS
    aight thanks, just ordered the H4 HID's which is said to have both high/low beams (8000k)
  11. Dec 10, 2012 at 11:06 AM
    Fisher
    Fisher Well-Known Member
    Salem, OR
    2007 2.7 SR5
    K&n Drop In, Secondary filter removed, 5k Headlights, 3K fog lights. Vvt-I sticker (plus 15 HP), Magnapack muffler
    Bi-xenon bulbs have high beams. They pull the bulb back slightly when you flip your high beams on.
  12. Dec 10, 2012 at 11:09 AM
    nammer
    Nam
    Bradenton, Florida
    they may have diff set ups, but I know of one kind, that they are actually 2 different bulbs, the hid, and a halogen high, so when u flip the switch, it cuts off the hid and switches the halogen on
  13. Dec 10, 2012 at 11:12 AM
    LBFD2005
    MS
    so would this be the case with the H4's?
  14. Dec 10, 2012 at 11:16 AM
    nammer
    Nam
    Bradenton, Florida
    yea, h4's and 9003 are the same for our truck, and yea the h4's are like that, I'm not saying that fisher is wrong, but I find that very implausible, unless you're talkin about super luxury car, when u have a high/low setup on the same bulb on our trucks, there are three terminals, one is ground, one is for low power, and one is for high power, when u click on high, low goes out
  15. Dec 10, 2012 at 11:18 AM
    nammer
    Nam
    Bradenton, Florida
    here's a pic of a bixenon bulb
    this one is actually 2 hid's
  16. Dec 10, 2012 at 11:20 AM
    Aw9d
    Aw9d That one guy
    Az
  17. Dec 10, 2012 at 11:22 AM
    LBFD2005
    MS
    so looks like ill have a halogen plus HID?? any suggestions on where to get the bi-xenon HID?
  18. Dec 10, 2012 at 11:29 AM
    nammer
    Nam
    Bradenton, Florida
    u could have 2 hid's? I didn't realize there was a difference, i would think the halogen would be better for a high, because it'll come on instantly, where HID needs to warm up, and I heard the quick on/off is not good for hid's (not sure about that) I've had good luck with ebay hid's, but a lot of people recommend ddmtuning.
  19. Dec 10, 2012 at 11:30 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    This, there are two types. One has two bulbs, one has a shield that a solenoid retracts the bulb to redirect light to a different place on the reflector to produce high and low beams these are know as Bi-Xenon. Neither is even close to what a projector will produce, light wise.
  20. Dec 10, 2012 at 11:33 AM
    nammer
    Nam
    Bradenton, Florida
    my apologies to fisher then, so how does the solenoid retract? electrically from the power given from the harness?
