HID Kit for the 2009 tacoma
Discussion in 'Lighting' started by IdealError, Dec 14, 2008.
  1. Dec 14, 2008 at 8:50 PM
    IdealError
    IdealError [OP] Active Member
    Orange County, CA
    09 PreRunner SR5 Sport
    6" Fabtech lift, 18" KMC XD Addicts on 35" Toyo MT Tires, 8000k HID Lights/Fogs, T-Rex Billet Grille, Viper 5900 Remote Start/Alarm, LED Projector Headlights, 15% Tint fronts, 5% Tint back, Eclipse Head Unit
    A friend of mine who works in the industry told me something about when installing an HID kit into an 09 that there are some flicker problems and the lights may shut off. He said it has something to do with the computer and what not.
    He mentioned he knows a way to wire up an anti-flicker "mechanism" so that the lights do not go off.
    Does anyone know about this or if this is true?
    Thanks!
  2. Dec 15, 2008 at 4:32 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I have the HID install on my 2009 Tacoma without any problem.
    I believe it is the HIT kit that he install have problem.
  3. Jan 14, 2009 at 9:49 AM
    MMMPinkTACOs
    MMMPinkTACOs Member
    California
    Bone stock.. for now!
    which HID kit did you install??
  4. Jan 14, 2009 at 9:55 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    With that i would double check install how the plugs are in as well as a good ground.
  5. Jan 14, 2009 at 10:49 AM
    wing103
    Boston
    I install the one with Hi-Low Beam (magnetic motor control High/Low) it cost about $220.00
    But than one of my friend tell me that in my area, there is a dealer have the same kit cost only $100. If anyone wants it, I can ask him for details.
  6. Jan 14, 2009 at 7:58 PM
    MMMPinkTACOs
    MMMPinkTACOs Member
    California
    Yeah if you can. Hook me up with the contact info and website if any. Also the brand of the kit. thnx
  7. Jan 14, 2009 at 10:21 PM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, Toyo
    It is most likely the HID kit. I have the same problem on my 05 when I installed the Hi/Lo HID kit. One light would flicker randomly, checked the connections, even warrantied the bulb and ballast, which cured the problem. But since then I have changed to a different HID kit where it does not need to "warm" up to temp. As soon as you turn them on, it's at the correct temp/kelvin the lights are supposed to be at
  8. Jan 15, 2009 at 4:03 AM
    wing103
    Boston
    Let me try to find out the info for you.
  9. Jan 18, 2009 at 9:28 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    hids in my 09 has no problems love my hids
