HID Kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jsroth17, Dec 16, 2015.
  1. Dec 16, 2015 at 10:11 AM
    jsroth17
    jsroth17 [OP] Well-Known Member
    New York
    2011 Tacoma TRD
    I have seen people posting about plug and play HID kits.
    If I wanted to do HID's/LED's on my 16 off road in head and fog lights, what would I need?
    proven21 likes this.
  2. Dec 16, 2015 at 10:17 AM
    barnett
    barnett Well-Known Member
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
    H11 kit for low beams. I would hold off on the retrofit source gets the jiggles worked out of theirs,
  3. Dec 21, 2015 at 4:18 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Xenondepot has an H11 headlight LED conversion kit. It uses the copper wick system instead of a fan that can get clogged with dust and doesn't require as much room behind the light. They also have a plug and play fog light kit for LED wide beam. I purchased both and so far I am very happy. I did get the add on canbus for the headlights because I have the DRL LEDs. Easy install. I unbolted the washer fluid tank and moved it over a bit to get more room on passenger side. Took me about 30 minutes to replace all four lights. I went with a super white halogen H9 for the high beams. It was less expensive and pretty much matches the color of the LEDs and I was concerned LEDs wouldn't be powerful enough for distance for the high beams.
  4. Dec 21, 2015 at 4:36 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    H11B for projector. H11A (wide angle) or H16C (normal) for fogs. H9B for high beam.
    Some of my opinions:
    • I do not recommend putting HIDs anywhere except behind the projector lens.
    • HIDs are brighter than LEDs, for now.
    • Morimoto HIDs have been used by a solid number of members on here and many have had great results.
    • https://www.theretrofitsource.com is a good place to purchase from.
    • 4300k is factory HID color temp (slightly yellow tinted). arguably the best at doing its intended job.
    • 3000k is yellow. 5000k is pure white. 6000k is slightly blue.
    • Less than 3000k and greater than 6000k are garbage.
