Hid kits
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dedgerly321, Dec 10, 2009.
  1. Dec 10, 2009 at 11:43 AM
    dedgerly321
    dedgerly321 [OP] Member
    DEDGE
    N.H.
    08 tacoma rugged trail trd crew cab
    halo projector headlights, hid fog lights, 20" liquid metal wheels, cold air intake
    I just recently replace all my cheap bulbs with HID kits, i when with the 6000k for the low, high and fog lights. i do run the aftermarket projector halo lights, so i had to buy 3 kits, got them off ebay for 41.50 with shipping. pics to come soon, highly suggest people to buy these makes a big difference and in the snow they are amazing
  2. Dec 10, 2009 at 11:46 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Overkill having them in your high beams IMO.
  3. Dec 10, 2009 at 11:48 AM
    dedgerly321
    DEDGE
    N.H.
    its not overkill, buy them and find out...
  4. Dec 10, 2009 at 11:50 AM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    got a link from ebay?
  5. Dec 10, 2009 at 11:50 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Just make sure you properly adjust the lights, there are a few cool guys on this forum who thinks its ok to blind the f out of people.
  6. Dec 10, 2009 at 11:56 AM
    jtav2002
    Josh
    Reading, PA
    Thanks, but I've ran HID's in previous vehicles, so I'm not exactly new to HID's. I never even really used highs with HID's installed in the lows, not much of a need for it. If you drive for long long periods of time with them on, it's fine. But it's not good if you're going to use them to signal someone to go, or pass, etc, like most people do. Not great for the ballasts. Plus since HID's take a bit to warm up to full brightness it's not ideal if you quickly need your highs.
    That's why I won't put HID's in my Taco seeing as it sits up higher and is more likely to blind someone regardless of how they're angled. In the cars I've ran them in it wasn't too much of a problem with them adjusted properly since the vehicle was lower to the ground.
  7. Dec 10, 2009 at 11:57 AM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Hell Yeah!! I live in Germany, you really learn to appreciate really bright head lights. Especially when you are flying down the Autobahn at 120mph and a Porche comes up behind you going 160 mph. Get out of the way!!
  8. Dec 10, 2009 at 12:02 PM
    jonny
    jonny Betty White Edition Heep ZJ
    waitin for Yosh to see this thread....:laugh:
  9. Dec 10, 2009 at 12:05 PM
    red taco
    red taco Well-Known Member
    Cole
    La Verne, CA
    07 PreRunner Impulse Red Pearl
    I'm no pro on HID's but our trucks have the same bulb for hi and low so in theory they shouldnt take time to heat up for hi beams if the headlights are already on should it?
  10. Dec 10, 2009 at 12:06 PM
    red taco
    Cole
    La Verne, CA
    On the same note as my post above, our trucks run a single hi/low bulb so do you not have high beams now? I'm a bit confused
  11. Dec 10, 2009 at 12:08 PM
    dedgerly321
    DEDGE
    N.H.
    that is true, but i do travel on back roads for a distance without seeing a car for miles, so in my area they work out perfect
  12. Dec 10, 2009 at 12:10 PM
    dedgerly321
    DEDGE
    N.H.
    where did you get those headlight top covers?
  13. Dec 10, 2009 at 12:10 PM
    jtav2002
    Josh
    Reading, PA
    Not sure how a bi-xenon setup works where it's one bulb. Dunno if there is a shield that moves, or if there is a seperate halogen high beam bulb attached, which I've seen before on some cars. He has the aftermarket projector lights so they have a separate high and low beam bulb.
  14. Dec 10, 2009 at 12:11 PM
    dedgerly321
    DEDGE
    N.H.
    i have aftermarket projector lights, lows are projector and highs are normal
  15. Dec 10, 2009 at 12:14 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    The bi-xenons have a magnet behind the bulb so when you hit your high beams, it sucks the bulb back to give it the high beam effect.
  16. Dec 10, 2009 at 12:15 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    How do you aim lights?
  17. Dec 10, 2009 at 12:24 PM
    red taco
    Cole
    La Verne, CA
    So running them in our trucks isnt an issue. Sorry I know your running projectors with seperate hi/lo. I was asking more as a personal question since I have a set sitting at home waiting for me to get home from England.
  18. Dec 10, 2009 at 12:26 PM
    red taco
    Cole
    La Verne, CA
  19. Dec 10, 2009 at 12:41 PM
    red taco
    Cole
    La Verne, CA
    So then when you engage the high switch nothing happens for you?
  20. Dec 10, 2009 at 12:42 PM
    tim920
    Tim
    Boston, MA
