HID Lights from DDM
Discussion in 'Lighting' started by lowrider, Feb 26, 2010.
  1. Feb 26, 2010 at 2:06 PM
    lowrider
    lowrider [OP] Member
    Houston
    2008 Tacoma V6
    Cold Air, driving lights, royal purple
    I got my DDM HID kit the other day and installed them already. They are nice and better than I expected. I have the Hi/Lo setup. I have a question. The bulbs have a metal casing around them that totally enclosed the bulb except for an open slot on the bottom. Why did they do this? Has anyone removed this casing? Did it create any problems? Were the headlights too bright on low?
    Thanks
  2. Feb 26, 2010 at 2:07 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    edit: i'm dumb :anonymous:
  3. Feb 26, 2010 at 2:12 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Yes that is the shield for high low beams. The big opening in the top is for low. The light comes out of the top and reflects off the top of the reflector then down at the road. When you actuate the high beams a solenoid pulls the center of the bulb where all the light comes from back into the window that faces down. this allows light to come out the bottom hit the bottom of the reflector and light up higher for high beams. DO NOT REMOVE IT you will blind the shit out of everyone.
  4. Feb 26, 2010 at 2:16 PM
    lowrider
    Houston
    2008 Tacoma V6
    Thanks for the answer. I am glad that I asked because I had no idea that the casing did this. Saved me a bunch of time and frustration!
  5. Feb 26, 2010 at 2:16 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the hole in the shield needs to be on the top. the bulbs stays tucked in while in low beam mode, when you hit the high beams the bulb moves up out of the hole making it brighter
  6. Feb 26, 2010 at 2:25 PM
    BSPDX
    BSPDX Well-Known Member
    I just ordered a kit today from them... 35w bixenon slim 4500k. I hope I like!
  7. Feb 26, 2010 at 2:58 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    whats the problem? heard nothing but good things from their kits
  8. Feb 26, 2010 at 3:10 PM
    CopDoctor
    08 335i
    wording wasn't too good on that post...the kit is decent. one bulb is a shade cooler than the other and the other bulb pulses..hard to explain but while the light is on right in the middle of the light spread it looks like the light is a beating heart, only the very center is moving like that, but that's not too bad. what i actually hate is my projectors..awful cutoff, and uneven spreads.
  9. Feb 26, 2010 at 3:13 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    sounds like it may just be your projectors....have you tried contacting ddm about the flicker?
  10. Feb 26, 2010 at 3:19 PM
    CopDoctor
    08 335i
    nah, i'm using the ballasts and have a new setup coming from the retro source.
    btw if anyone wants/needs any 6000k H7 bulbs i've got em!
