HID Lo Beams not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongestMilk, May 12, 2018.
  1. May 12, 2018 at 3:40 PM
    LongestMilk
    LongestMilk [OP] Member
    Jake
    2001 2.7L Black Tacoma 4x4
    3" Lift, Falken A/T 33 tires
    Hello,
    I recently purchased new head lights from protuning lab because mine were extremely faded and I wanted to upgrade to HIDs. Everything was pretty straight forward with the install and they fit actually good. Well upon trying to test the lights, both Lo beams do not come on, but the Hi beams come on. Also to note, while the Hi beams are on the blue light indicator on the dash does not come on. I tried searching for a while but could not come up with a solution. I have a 2001 2.7L manual.
  2. May 12, 2018 at 3:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    What does the vendor suggest?
  3. May 12, 2018 at 3:44 PM
    LongestMilk
    Jake
    No instructions were included and they are closed on the weekend so I cannot call...
  4. May 12, 2018 at 9:31 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Wiring is probably backwards. You'll need to swap pins on the H4 connector. The ones for hi/low beam. Can't remember which. I had this problem before with a TRS relay. I believe they may have some info on their website about it.
  5. May 16, 2018 at 7:04 PM
    LongestMilk
    Jake
    Tried swapping the pins in every possible variation and the only light that came on was the Hi beam still. What baffled me was, I then put the pins directly on the battery terminals and still only the Hi beams. I even tried on both hids with the same results. It leads me to believe they sent me faulty bulbs and/or ballasts.
  6. May 16, 2018 at 7:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Some cheap hid bulbs on ebay only have one beam... idk wher eyou got yours
  7. May 17, 2018 at 6:44 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I think it's an h1 high and hid projector low setup. In any case did you check the hids before you installed them by providing 12v/ground to the ballast. After that tests out we need to know what plug to ballast setup you have. Are you running a relay harness? Without any pictures it's kinda hard to know what your dealing with and what the problem is.
